Hi, I was just wondering if someone could add an actual example of what the CATALINA_OPTS environment variable should look like? The information on http://geoserver.org/display/GEOSDOC/6+GeoServer+in+Production+Environment is excellent, but I had to do a bit of research to figure out how to implement the advice that’s located there. I ended up adding the following line to my .bashrc (this is on a Fedora 8 system), and it works great.
export CATALINA_OPTS=“-server -Xms48m -Xmx256M”
Roger
Roger André
GIS Developer/Analyst
Enterprise Management Solutions
CH2M HILL
1100 112th Avenue NE
Suite 400
Bellevue, WA 98004
Direct 425.233.3042
roger.andre@anonymised.com
Developing People through Challenging Projects
Hi Roger,
I think there are quite many places where you can put it. I am using centos and starting tomcat with jsvc script:
http://tomcat.apache.org/tomcat-6.0-doc/setup.html (unix daemon)
so the java options are defined in tomcat (jsvc) script.
It can also be put into catalina.sh in $TOMCAT_HOME/bin under JAVA_OPT if you are starting with startup.sh. Probably many other alternatives exists.
What you can put in your java options depends on your java. Here is a good link with plenty of useful sublinks:
http://blogs.sun.com/watt/resource/jvm-options-list.html
If you are concerning of your Tomcat's performance, use jconsole or some other tool for monitoring. Please let me know if I can help more.
cheers
mika
Roger.Andre@anonymised.com kirjoitti:
Hi, I was just wondering if someone could add an actual example of what the CATALINA_OPTS environment variable should look like? The information on http://geoserver.org/display/GEOSDOC/6+GeoServer+in+Production+Environment is excellent, but I had to do a bit of research to figure out how to implement the advice that's located there. I ended up adding the following line to my .bashrc (this is on a Fedora 8 system), and it works great.
export CATALINA_OPTS="-server -Xms48m -Xmx256M"
Roger
Roger André
CH2M HILL
Suite 400
Bellevue, WA 98004
Direct 425.233.3042
roger.andre@anonymised.com <mailto:roger.andre@anonymised.com>
Defy all challenges. Microsoft(R) Visual Studio 2008.
Geoserver-users mailing list
Yep,
should be using TomCat Manager and its server status. You may suprise what java you are using and what are the memory settings and so on; anyway if you have tested different versions. Learn to use jconsole. There you have everything you ever need to know about your engine under the hood. At least it's enough for me.
mika
Hi Mika,
Thanks for the information. I had no idea that the settings could be set in so many places.
Roger
-----Original Message-----
From: Lehtonen, Mika [mailto:mika@anonymised.com] Sent: Wednesday, March 19, 2008 12:24 PM
To: Andre, Roger/SEA
Subject: Re: [Geoserver-users] Tomcat optimization: CATALINA_OPTS entry
Hi Roger,
http://tomcat.apache.org/tomcat-6.0-doc/setup.html (unix daemon) so the java options are defined in tomcat (jsvc) script.
cheers
mika
Roger
Roger André
CH2M HILL
Suite 400
Bellevue, WA 98004
Direct 425.233.3042
--- This SF.net email is sponsored by: Microsoft Defy all challenges. Microsoft(R) Visual Studio 2008.
I'm trying to stylize a layer and am getting the following error:
java.lang.IllegalArgumentException: Argument "value" should not be null.
at org.geotools.util.SoftValueHashMap.ensureNotNull(SoftValueHashMap.java:103)
at org.geotools.util.SoftValueHashMap.put(SoftValueHashMap.java:226)
at org.geotools.renderer.style.SLDStyleFactory.createStyle(SLDStyleFactory.java:308)
at org.geotools.renderer.lite.StreamingRenderer.processSymbolizers(StreamingRenderer.java:1732)
at org.geotools.renderer.lite.StreamingRenderer.process(StreamingRenderer.java:1659)
at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:1603)
at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:648)
at org.geotools.renderer.shape.ShapefileRenderer.renderWithStreamingRenderer(ShapefileRenderer.java:1422)
at org.geotools.renderer.shape.ShapefileRenderer.paint(ShapefileRenderer.java:1296)
at org.geotools.renderer.shape.ShapefileRenderer.paint(ShapefileRenderer.java:262)
at org.vfny.geoserver.wms.responses.DefaultRasterMapProducer.produceMap(DefaultRasterMapProducer.java:286)
at org.vfny.geoserver.wms.responses.GetMapResponse.execute(GetMapResponse.java:432)
Unfortunately, the error does not tell me a whole lot. Any ideas about what the cause of this error might be or how to track it down? TNX David
David R Robison
Open Roads Consulting, Inc.
708 S. Battlefield Blvd., Chesapeake, VA 23322
phone: (757) 546-3401
e-mail: drrobison@anonymised.com
web: http://openroadsconsulting.com
blog: http://therobe.blogspot.com
book: http://www.xulonpress.com/book_detail.php?id=2579
For long features, is it possible to specify in the SLD that a label should be repeated for a feature? TNX David
David R Robison
I was upgrading from 1.6.0 to 1.6.2a and now get the following error:
Cannot register alias 'catalog' for bean name 'data': it's already registered for bean name 'data'
I downloaded and installed the WAR. Any thoughts? David
David R Robison
My fault, I expanded the WAR without removing the previous directory. David
David R Robison
e-mail: [drrobison@anonymised.com](mailto:drrobison@anonymised.com)
web: [http://openroadsconsulting.com](http://openroadsconsulting.com)
blog: [http://therobe.blogspot.com](http://therobe.blogspot.com)
book: [http://www.xulonpress.com/book_detail.php?id=2579](http://www.xulonpress.com/book_detail.php?id=2579)
Upgrading to 1.6..2a fixed the problem. David
David R Robison
No, it is not. The steps to have it would be:
a) file a jira issue asking for that (otherwise we'll forget)
b) either:
- provide a patch for it
- wait for developers to have a need for it
- sponsor someone to implement it
Definitely file a feature improvement for it. I could see this fall into the group of "Vendor Options" for labelling. Discussed here:
http://docs.codehaus.org/display/GEOSDOC/LabelingOptions
Andrea: Are all the options listed on that page still relevant?
-Justin
b) either:
!DSPAM:4007,47e80e24286971096210785!
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Most of the are part of the SLD standard so yes, they are. Priority
is a vendor extension, I've never tried to use it, but I'm not aware
of someone intentionally breaking it either, so it should be still
working.
Can someone explain the Postgis Data Store parameters:
max connections
min connections
validate connections
Thanks, David
David R Robison
max connections
min connections
I've tried to embed the response in this wiki page:
http://geoserver.org/display/GEOSDOC/Connection+pooling+options+(for+DBMS+based+datastores)
Let me know if it's clear enough.
Under high load, we are occasionally seeing what appears to be a deadlock situation. We ran a full thread dump in the Tomcat process and found two threads that appear to be in a deadlock situation. Here are their stack traces: Notice the locks on addresses 0x078fdb20 and 0x07c332b0.
"http-8080-2" daemon prio=6 tid=0x4cf12000 nid=0x7dc waiting for monitor entry [0x4e94d000..0x4e94fb98]
java.lang.Thread.State: BLOCKED (on object monitor)
at org.geotools.metadata.iso.citation.CitationImpl.getIdentifiers(CitationImpl.java:292)
- waiting to lock <0x07c332b0> (a org.geotools.metadata.iso.citation.CitationImpl)
at sun.reflect.GeneratedMethodAccessor35.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.geotools.metadata.PropertyAccessor.get(PropertyAccessor.java:339)
at org.geotools.metadata.PropertyAccessor.shallowEquals(PropertyAccessor.java:420)
at org.geotools.metadata.MetadataStandard.shallowEquals(MetadataStandard.java:283)
at org.geotools.metadata.AbstractMetadata.equals(AbstractMetadata.java:160)
- locked <0x078fdb20> (a org.geotools.metadata.iso.citation.CitationImpl)
at org.geotools.resources.Utilities.equals(Utilities.java:53)
at org.geotools.referencing.NamedIdentifier.equals(NamedIdentifier.java:670)
at org.geotools.referencing.AbstractIdentifiedObject.equals(AbstractIdentifiedObject.java:858)
at org.geotools.referencing.AbstractReferenceSystem.equals(AbstractReferenceSystem.java:164)
at org.geotools.referencing.crs.AbstractCRS.equals(AbstractCRS.java:159)
at org.geotools.referencing.crs.AbstractSingleCRS.equals(AbstractSingleCRS.java:154)
at org.geotools.referencing.AbstractIdentifiedObject.equals(AbstractIdentifiedObject.java:824)
at org.vfny.geoserver.global.GeoServerFeatureSource.reprojectFeatureCollection(GeoServerFeatureSource.java:396)
at org.vfny.geoserver.global.GeoServerFeatureSource.getFeatures(GeoServerFeatureSource.java:321)
at org.geoserver.wfs.GetFeature.getFeatures(GetFeature.java:345)
at org.geoserver.wfs.GetFeature.run(GetFeature.java:257)
at org.geoserver.wfs.DefaultWebFeatureService.getFeature(DefaultWebFeatureService.java:108)
at sun.reflect.GeneratedMethodAccessor111.invoke(Unknown Source)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:292)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:155)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:122)
at org.geoserver.wfs.WFSLogger.invoke(WFSLogger.java:44)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:144)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:174)
at $Proxy0.getFeature(Unknown Source)
at sun.reflect.GeneratedMethodAccessor128.invoke(Unknown Source)
at org.geoserver.security.OperationSecurityInterceptor.invoke(OperationSecurityInterceptor.java:41)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:495)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:188)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:357)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:69)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:263)
at org.apache.coyote.http11.Http11AprProcessor.process(Http11AprProcessor.java:852)
at org.apache.coyote.http11.Http11AprProtocol$Http11ConnectionHandler.process(Http11AprProtocol.java:584)
at org.apache.tomcat.util.net.AprEndpoint$Worker.run(AprEndpoint.java:1508)
at java.lang.Thread.run(Unknown Source)
"http-8080-1" daemon prio=6 tid=0x4ce4a400 nid=0x1248 waiting for monitor entry [0x4e8cd000..0x4e8cfc98]
- waiting to lock <0x078fdb20> (a org.geotools.metadata.iso.citation.CitationImpl)
- locked <0x07c332b0> (a org.geotools.metadata.iso.citation.CitationImpl)
at org.geotools.data.crs.ForceCoordinateSystemFeatureResults.forceType(ForceCoordinateSystemFeatureResults.java:95)
at org.geotools.data.crs.ForceCoordinateSystemFeatureResults.<init>(ForceCoordinateSystemFeatureResults.java:71)
at org.geotools.data.crs.ForceCoordinateSystemFeatureResults.<init>(ForceCoordinateSystemFeatureResults.java:66)
at org.vfny.geoserver.global.GeoServerFeatureSource.reprojectFeatureCollection(GeoServerFeatureSource.java:397)
Any thoughts as to what the problem might be or how to get around this? Thanks, David
David R Robison
Created a JIRA task:
http://jira.codehaus.org/browse/GEOT-1777
Thanks for reporting,
Martin
If I set SRSHandling to LEAVE, will it not call this code and thus not risk a deadlock? TNX David
Martin Desruisseaux wrote:
David R Robison
No, it will reach the same code using a different path. It's a matter
of time and bad luck, but eventually it will deadlock anyways...
We are about to go into production on a system that makes heavy use of geoserver. Any thoughts as to how to work around this? Any help would be appreciated. TNX David
David R Robison
No idea... it seems to be a bug in the code and has to be resolved
as such... the only thing that might help is a patch.
I am using a PostGIS data store, is it possible to request that the returned features be sorted in a WFS call? TNX David
David R Robison
