Here it is ! (and it seems to be good)
ps -lfe | grep java
0 S tomcat 1894 1 2 80 0 - 937413 ? 11:22 ? 00:00:57 /usr/bin/java -Djava.util.logging.config.file=/usr/share/tomcat/conf/logging.properties -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager -Djava.security.egd=file:/dev/urandom -server -Xms2G -Xmx2G -XX:PermSize=512m -XX:MaxPermSize=512m -Djava.awt.headless=true? -Djava.endorsed.dirs=/usr/share/tomcat/endorsed -classpath /usr/share/tomcat/bin/bootstrap.jar:/usr/share/tomcat/bin/tomcat-juli.jar -Dcatalina.base=/usr/share/tomcat -Dcatalina.home=/usr/share/tomcat -Djava.io.tmpdir=/usr/share/tomcat/temp org.apache.catalina.startup.Bootstrap start
0 S max76 2042 1359 0 80 0 - 3185 - 11:56 pts/0 00:00:00 grep java
But I don’t know why my geoserver Layer preview doesn’t work…
For information, I try to test geoserver installed on debian (guest virtual box) and my PostGis data is on host (windows 7)
De : Stefano Costa [mailto:stefano.costa@anonymised.com]
Envoyé : vendredi 30 octobre 2015 11:53
À : Maxence MELIN
Cc : geoserver-users@lists.sourceforge.net
Objet : Re: [Geoserver-users] Tomcat tuning for geoserver - Layer previews all blank
On Fri, Oct 30, 2015 at 11:35 AM, Maxence MELIN <maxence.melin@anonymised.com> wrote:
I just tried it, but
my layer previews are still blank frames L
I did that in my setenv.sh file :
export CATALINA_OPTS=“$CATALINA_OPTS -server -Xms2G -Xmx2G -XX:PermSize=512m -XX:MaxPermSize=512m -Djava.awt.headless=true”
Is it OK ? is there any difference between catalina_opts and java_opts ?
They are used in different places, but for your purposes they should be equivalent.
Can you open a terminal, run this command:
ps -lfe | grep java
…and share the output? We should be able to confirm that Tomcat actually picked up your custom options by looking at the command run by the startup script.
Envoyé : vendredi 30 octobre 2015 11:30
À : Maxence MELIN
On Fri, Oct 30, 2015 at 10:39 AM, Maxence MELIN <maxence.melin@anonymised.com> wrote:
I work on Debian Jessie with JAVA7, Tomcat 8, Geoserver 2.8 and Iceweasel as web browser.
To improve Tomcat and geoserver use I created a setenv.sh file with export CATALINA_OPTS=“$CATALINA_OPTS -server -Xms2G -Xmx2G -XX:PermSize=512m -XX:MaxPermSize=512m”
Is it good ? CATALINA seems to be just for the loading of tomcat, so does it make sense to increase the PermSize in Catalina in order to optimize Geoserver ? Where to that then ?
Should be OK, Tomcat should pick those up on startup.
I need also to add JAVA_OPTS=“-Djava.awt.headless=true” but I don’t know where (somebody told me to set it in /etc/default/tomcat but it doesn’t exist for me… where am I supposed to set this java option ?)
You can add it in your setenv.sh script as well.
I may solve my blank layer preview problem…
If you have other advice to optimize geoserver, don’t hesitate to say !
Thanks for your help !
Max
Maxence MELIN
Direction des Systèmes d’Information
Fédération Nationale des Safer
91 rue du Faubourg Saint Honoré
75 008 PARIS
Tél : 01 44 69 86 08
![signature2013ok]()
Geoserver-users mailing list
Best regards,
Stefano Costa
[http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Dott. Stefano Costa
Senior Software Engineer
Via Poggio alle Viti 1187
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
Best regards,
Stefano Costa
Dott. Stefano Costa
D.Lgs. 196/2003.
