I don't understand, I created a new layer with a very ligth SHP (1ko) and got this message when I wanted to preview on geoserver with openlayers :
<?xml version="1.0" encoding="UTF-8" standalone="no"?><!DOCTYPE ServiceExceptionReport SYSTEM "http://localhost:8180/geoserver/schemas/wms/1.1.1/WMS_exception_1_1_1.dtd"> <ServiceExceptionReport version="1.1.1" > <ServiceException>
java.lang.OutOfMemoryError: PermGen space
PermGen space
</ServiceException></ServiceExceptionReport>
-----Message d'origine-----
De : Maxence MELIN [mailto:maxence.melin@anonymised.com]
Envoyé : vendredi 30 octobre 2015 17:33
À : geoserver-users@lists.sourceforge.net
Objet : Re: [Geoserver-users] Tomcat tuning for geoserver - Layer previews all blank
Hi Tom,
It's only the expected content that's missing, the normal map controls are here.
I try with a SHP to see if the problem comes from my PostGis data
De : Tom S [mailto:tom-sourceforge@anonymised.com]
Envoyé : vendredi 30 octobre 2015 17:24
When you say blank, is the expected content missing, or are some of the normal map controls also missing? For recent releases of geoServer it seems that the system has a new/different dependency for the OpenLayers library used for preview - if you are accessing geoServer via a proxy, you will need a new path to be recognized that routes this traffic to the appropriate tomcat. I ended up adding (for apache httpd)
ProxyPassMatch ^/openlayers3/(.*)$
ajp://localhost:8009/geoserver/openlayers3/$1
I'm not sure if this is a bug in geoServer (Windows builds), or some other underlying change (tomcat, ....), but either the system is now expecting a distinct (root dir) install of openlayers, or part of the path was omitted by geoserver in its calls. I haven't checked this for direct tomcat use (no proxy), but suspect even there the shortened path will cause issues.
Geoserver-users mailing list
