[Geoserver-users] tomcat7 wont start with -XX:+UseParallelGC
I have geoserver up and running but during install (aws Ubuntu 14.04) i
found http://docs.geoserver.org/stable/en/user/production/container.html
recommends setting -XX:+UseParallelGC. This caused Tomcat7 to fail to start.
I found reference elsewhere to -XX:+UseParNewGC being similar. With this
setting Tomcat7 and consequently GeoServer does run but i wonder whether
anyone has had a similar issue and/or knows whether this alternative setting
is really going to have the desired effect?
Thanks
Andy
View this message in context: http://osgeo-org.1560.x6.nabble.com/tomcat7-wont-start-with-XX-UseParallelGC-tp5150938.html
Andy,
I am using GeoServer 2.5.1 and Tomcat 7.0.54 on a Windows 2008 R2 server,
and I am using -XX:+UseParallelGC as one of my JAVA startup parameters
without any problem. Could something else be causing Tomcat to fail to
start? I am not familiar with the other setting that you mentioned.
Jerome Wendell
-----Original Message-----
Sent: Monday, July 14, 2014 11:31 AM
Subject: [Geoserver-users] tomcat7 wont start with -XX:+UseParallelGC
Thanks
Andy
-tp5150938.html
Want fast and easy access to all the code in your enterprise? Index and
search up to 200,000 lines of code with a free copy of Black Duck® Code
Sight™ - the same software that powers the world's largest code search
on Ohloh, the Black Duck Open Hub! Try it now.
http://p.sf.net/sfu/bds
Geoserver-users mailing list
Hi Jerome,
Thanks for the response.
I tried removing the parameters one at a time when i had the issues. I found
that by just adding or removing this specific option (and no others) i would
get tomcat starting successfully or not.
Andy
View this message in context: http://osgeo-org.1560.x6.nabble.com/tomcat7-wont-start-with-XX-UseParallelGC-tp5150938p5150943.html
Andy,
Does the following affect your installation:
◦-XX:+UseConcMarkSweepGC
◦To enable a parallel young generation GC with the concurrent GC add -XX:+UseParNewGC to the startup. Don't add -XX:+UseParallelGC with this option.
Jerome
Sent: Monday, July 14, 2014 12:06 PM
Subject: Re: [Geoserver-users] tomcat7 wont start with -XX:+UseParallelGC
Hi Jerome,
I tried removing the parameters one at a time when i had the issues. I found that by just adding or removing this specific option (and no others) i would get tomcat starting successfully or not.
Andy
Want fast and easy access to all the code in your enterprise? Index and search up to 200,000 lines of code with a free copy of Black Duck® Code Sight™ - the same software that powers the world's largest code search on Ohloh, the Black Duck Open Hub! Try it now.
Jerome,
I added -XX:+UseConcMarkSweepGC and tomcat started. I tried it with and
without the -XX:+UseParNewGC
Does this help to identify what the issue with -XX:+UseParallelGC might be
or just add something to ensure i'm achieving the same? Apologies for my
ignorance and thanks again!
Andy
Jerome A. Wendell wrote
Andy,
option.
Jerome
andy@anonymised.com
To:
geoserver-users@anonymised.com
Hi Jerome,
Andy
Geoserver-users@anonymised.com
View this message in context: http://osgeo-org.1560.x6.nabble.com/tomcat7-wont-start-with-XX-UseParallelGC-tp5150938p5150952.html
Andy,
I am not sure of the answer to your question. Hopefully someone a lot more knowledgeable than myself on the list will respond to your question.
Jerome
Sent: Monday, July 14, 2014 12:35 PM
Jerome,
I added -XX:+UseConcMarkSweepGC and tomcat started. I tried it with and without the -XX:+UseParNewGC
Does this help to identify what the issue with -XX:+UseParallelGC might be or just add something to ensure i'm achieving the same? Apologies for my ignorance and thanks again!
Andy
Andy,
this option.
Jerome
andy@anonymised.com
To:
-XX:+UseParallelGC
Hi Jerome,
Andy
llelGC-tp5150938p5150943.html Sent from the GeoServer - User mailing
-------- Want fast and easy access to all the code in your enterprise?
now.
now.
What JVM are you using? What is the output of these commands?
update-alternatives --display java
java -version
On 14/07/14 23:31, AndyT wrote:
Thanks
Andy
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Mineral Resources Flagship
Australian Resources Research Centre
Hi Ben
Java versions as requested:
xxx@anonymised.com:~$ update-alternatives --display java
java - manual mode
  link currently points to /usr/lib/jvm/java-6-oracle/jre/bin/java
/usr/lib/jvm/java-6-oracle/jre/bin/java - priority 1
  slave java.1.gz: /usr/lib/jvm/java-6-oracle/man/man1/java.1.gz
Current 'best' version is '/usr/lib/jvm/java-6-oracle/jre/bin/java'.
xxx@anonymised.com:~$ java -version
java version "1.6.0_45"
Java(TM) SE Runtime Environment (build 1.6.0_45-b06)
Java HotSpot(TM) 64-Bit Server VM (build 20.45-b01, mixed mode)
Andy
java -version
start.
setting
Thanks
Andy
View this message in context: http://osgeo-org.1560.x6.nabble.com/tomcat7-wont-start-with-XX-UseParallelGC-tp5150938p5151083.html
Hmm, that looks fine.
How did you set -XX:+UseParallelGC? In JAVA_OPTS in /etc/default/tomcat7? If two contradictory options are provided, tomcat7 may refuse to start.
Did you see any errors in the logs or when running "service tomcat7 start"?
Kind regards,
Ben.
On 15/07/14 16:17, AndyT wrote:
Hi Ben
java - manual mode
Andy
java -version
start.
setting
Thanks
Andy
Code Sight - the same software that powers the world's largest code
Software Engineer
Hi Ben,
It's set in /etc/default/tomcat7
I currently have "-XX:+UseConcMarkSweepGC" in there on the suggestion of
Jerome from this post.
This is my current setting:
JAVA_OPTS="-Djava.awt.headless=true -server -Xmx512m -Xms48m
-XX:+UseConcMarkSweepGC -XX:MaxPermSize=128M
-XX:SoftRefLRUPolicyMSPerMB=36000 -XX:+UseParNewGC -XX:+UseConcMarkSweepGC"
This is the setting which fails:
-XX:SoftRefLRUPolicyMSPerMB=36000 -XX:+UseParallelGC "
Tomcat7 just shows "fail" when starting. I will check the logs as well.
Thanks
Andy
Kind regards,
Ben.
View this message in context: http://osgeo-org.1560.x6.nabble.com/tomcat7-wont-start-with-XX-UseParallelGC-tp5150938p5151102.html
Andy,
you have used two conflicting options, -XX:+UseConcMarkSweepGC and -XX:+UseParallelGC, in the same JAVA_OPTS. These refer to two different garbage collectors. For example:
$ java -XX:+UseConcMarkSweepGC -XX:+UseParallelGC
Conflicting collector combinations in option list; please refer to the release notes for the combinations allowed
Error: Could not create the Java Virtual Machine.
Error: A fatal exception has occurred. Program will exit.
If you want try try the parallel GC, remove -XX:+UseConcMarkSweepGC from the option list. (In fact I think the parallel collector is the default for your JDK for server class machines, so will be used if you specify no options, but it will not hurt to be explicit.)
Kind regards,
Ben.
Software Engineer
Hi Ben,
I'm new to Linux so excuse if i'm picking up the wrong logs. Catalina.out
seems to show a very likely issue:
Could not create the Java virtual machine.
Looking at my config again, i think i may have misunderstood Jeromes'
comment. I have now removed -XX:+UseConcMarkSweepGC and tomcat7 does start
Seems to be running ok now. Not sure where i got that setting originally,
perhaps it was a default. Thanks so much for help
Andy
View this message in context: http://osgeo-org.1560.x6.nabble.com/tomcat7-wont-start-with-XX-UseParallelGC-tp5150938p5151106.html
