[Geoserver-users] TR : Line label placement improvement
Hi Andrea, hi list,
We would like to submit a patch to improve line label placement in Geotools.
We are producing maps with a lot of street names using Geoserver. We noticed that many labels could not be placed because areas used to manage conflicts are quite big when labels follow diagonal directions.
We decided to manage the label index using “letters” bounding boxes rather than “label” bounding boxes. This improve noticeably the number of placed labels (it is not possible to tell how many more as it is highly data-dependant). The performance penalty does not seem very high (indeed, we could not really measure it).
Currently, we have implemented the change as a vendor option named “letterConflictEnabled”. But if the code is good enough, it could also replace the current one at some point.
Please, let us know if you’re interested by this patch. It includes some unit tests and can be submitted as a PullRequest on the current GeoTools 14-SNAPSHOT.
Here attached is a small document explaining the change.
Michaël Michaud and Mathieu Lemarchand for
Institut Géographique National (France)
ImproveLabelPlacement.pdf (93.8 KB)
Hi Michael,
I’ve been hoping to find the time to do something similar for quite a while now, so this is certainly welcomed.
I’d suggest you make a pull request with these changes enabled by default, and maybe have a system variable to disable
it in case we find situations in which the performance slowdown is noticeable?
On Mon, Aug 24, 2015 at 10:22 AM, Michael Michaud <Michael.Michaud@anonymised.com> wrote:
Hi Andrea, hi list,
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Oh, forgot, the feature freeze in in 4 days, after that, the pull request will be merged against the GeoTools 15.x/GeoServer 2.9.x series
On Mon, Aug 24, 2015 at 10:35 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Michael,
Hi Andrea, hi list,
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Andrea,
OK, I changed the way to activate the option (vendorOption → system variable), but I can’t create a pull request. I get the following error from my IDE:
Push failed:
unable to access ‘https://github.com/geotools/geotools/’: The requested URL returned error: 403
Maybe I should have created my fork on github first instead of checking out directly from geotools/geotools ?
I’ll try this tomorrow. Now that I removed the vendor option, there is only one file changed (out of test files)
Michaël
Hi Andrea, hi list,
Ing. Andrea Aime
@geowolf
Technical Lead
On Mon, Aug 24, 2015 at 8:34 PM, Michael Michaud <Michael.Michaud@anonymised.com.>
wrote:
Hi Andrea,
OK, I changed the way to activate the option (vendorOption -> system
variable), but I can't create a pull request. I get the following error
from my IDE:
Push failed:
unable to access 'https://github.com/geotools/geotools/': The requested
You are trying to push to the main repository, this is not a pull requset
:slight_smile:
You should create your fork, push your branch there, and then from that
one,
you'll be able to make a pull request (just check your project's github
page after
pushing the branch)
More info on the internet, e.g., here:
https://help.github.com/articles/creating-a-pull-request/
Ing. Andrea Aime
@geowolf
Technical Lead
Thank you for the help,
I think you get the pull request now.
I added a static variable DISABLE_LETTER_LEVEL_CONFLICT in LabelCacheImpl to be able to disable the new behaviour from system property “org.geotools.labelcache.disableLetterLevelConflict”.
It should probably be final but I needed to switch the option on and off in the unit tests.
Let us know if there is something else we can do to validate the patch.
Michaël
On Mon, Aug 24, 2015 at 8:34 PM, Michael Michaud <Michael.Michaud@anonymised.com> wrote:
Hi Andrea,
Push failed:
You are trying to push to the main repository, this is not a pull requset :slight_smile:
You should create your fork, push your branch there, and then from that one,
you’ll be able to make a pull request (just check your project’s github page after
pushing the branch)
Ing. Andrea Aime
@geowolf
Technical Lead
I a going to assume this is your pull request here (https://github.com/geotools/geotools/pull/948). We should probably be discussing it on geotools list. Let me review quickly now …
On 25 August 2015 at 08:58, Michael Michaud <Michael.Michaud@anonymised.com> wrote:
Michaël
De : andrea.aime@anonymised.com [andrea.aime@anonymised.com] de la part de Andrea Aime [andrea.aime@anonymised.com]
Date d’envoi : lundi 24 août 2015 20:37
À : Michael Michaud
Cc : geoserver-users@lists.sourceforge.net; Mathieu Lemarchand; Arnaud Braun
Objet : Re: RE : [Geoserver-users] TR : Line label placement improvement
Jody Garnett
Hi Andrea,
Push failed:
pushing the branch)
Ing. Andrea Aime
@geowolf
Technical Lead
