My Geoserver setup was working like a week ago. I didn't think I had changed
anything, but I tried connecting today with Udig and got the following. I
restarted geoserver and could log onto the administrative interface without
issue. Any ideas? Thanks.
Kevin
java.io.IOException: Could not connect to WMS. Possible reason: Translator
error
Translator error
Translator error
Translator error
at
net.refractions.udig.catalog.internal.wms.WMSServiceImpl.getWMS(WMSServiceImpl.java:124)
at
net.refractions.udig.catalog.internal.wms.WMSServiceImpl.getInfo(WMSServiceImpl.java:142)
at
net.refractions.udig.catalog.internal.wms.ui.WMSWizardPage.getResources(WMSWizardPage.java:290)
at
net.refractions.udig.catalog.internal.ui.ConnectionPage.getResources(ConnectionPage.java:72)
at
net.refractions.udig.catalog.internal.ui.ConnectionPage$1.run(ConnectionPage.java:127)
at
org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:346)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:291)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:830)
at
net.refractions.udig.catalog.internal.ui.ConnectionPage.getNextPage(ConnectionPage.java:147)
at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDialog.java:747)
at
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:345)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:556)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:90)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3125)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:2758)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:143)
at
net.refractions.udig.internal.ui.UDIGApplication.run(UDIGApplication.java:28)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(PlatformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:163)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334)
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Caused by: org.geotools.ows.ServiceException: Translator error
Translator error
Translator error
Translator error
at
org.geotools.data.wms.xml.WMSComplexTypes$_ServiceException.getValue(WMSComplexTypes.java:4741)
at
org.geotools.xml.handlers.ComplexElementHandler.endElement(ComplexElementHandler.java:155)
at org.geotools.xml.XMLSAXHandler.endElement(XMLSAXHandler.java:222)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endElement(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.dtd.XMLNSDTDValidator.endNamespaceScope(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator.handleEndElement(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator.endElement(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.scanEndElement(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown
Source)
at
Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown
Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.geotools.xml.DocumentFactory.getInstance(DocumentFactory.java:139)
at
org.geotools.data.wms.response.GetCapabilitiesResponse.<init>(GetCapabilitiesResponse.java:28)
at
org.geotools.data.wms.WebMapServer.internalIssueRequest(WebMapServer.java:353)
at org.geotools.data.wms.WebMapServer.issueRequest(WebMapServer.java:372)
at
net.refractions.udig.catalog.internal.wms.WMSServiceImpl$CustomWMS.issueRequest(WMSServiceImpl.java:328)
at
org.geotools.data.wms.WebMapServer.negotiateVersion(WebMapServer.java:177)
at org.geotools.data.wms.WebMapServer.<init>(WebMapServer.java:103)
at
net.refractions.udig.catalog.internal.wms.WMSServiceImpl$CustomWMS.<init>(WMSServiceImpl.java:317)
at
net.refractions.udig.catalog.internal.wms.WMSServiceImpl.getWMS(WMSServiceImpl.java:114)
... 32 more
View this message in context: http://www.nabble.com/Translator-Error-tf4719679.html#a13492365
