Good Day List,
Currently having an issue making a request to Geoserver using the Transparent argument. I currently have a list of image mosaic raster layers which are all generated the same way and added to geoserver the same way but yet only one works with ‘transparent=true.’
So that was convoluted. Anyway, make a WMS request and I get back an image.
Example: http://localhost:8080/geoserver/ENV-792B/wms?service=WMS&version=1.1.0&request=GetMap&layers=ENV-792B:300mb_For_Guppy&styles=&bbox=47.968125,23.989358857500005,64.968125,39.989358297500004&width=512&height=481&srs=EPSG:4326&format=image%2Fpng
Works Great, everybody happy.
Now I make a the same request with &transparent=true at the end and boom: java hates me and kicks me in the balls (Short copy below and GeoserverError.txt attached is the full request and error):
Error: One factory fails for the operation “Mosaic”
Occurs in: org.geoserver.jai.ConcurrentOperationRegistry
java.lang.reflect.InvocationTargetException
at sun.reflect.GeneratedMethodAccessor124.invoke(Unknown Source)
Caused by: java.lang.IllegalArgumentException: Alpha images must be single-banded.
at com.sun.media.jai.opimage.MosaicOpImage.(MosaicOpImage.java:234)
at com.sun.media.jai.opimage.MosaicRIF.create(MosaicRIF.java:47)
… 87 more
22 Apr 16:02:22 ERROR [geoserver.ows] -
java.lang.RuntimeException: - Unable to render RenderedOp for this operation.
Hmmm, unfortunate. Well for grins I was messing around testing and tried http://localhost:8080/geoserver/ENV-792B/wms?service=WMS&version=1.1.0&request=GetMap&layers=ENV-792B:300mb_For_Guppy,ENV-792B:300mb_For_Guppy&styles=&bbox=47.968125,23.989358857500005,64.968125,39.989358297500004&width=512&height=481&srs=EPSG:4326&format=image%2Fpng&transparent=true which is the same request just with the exact same layer twice and it works. Transparency works. Everyone is happy. I am using the default raster SLD that ships with geoserver but for grins I have gone through and changed it slightly to use use an opacity of 0.99 and no difference. I’m at a complete loss. Please tell me I’m doing something stupid and this is an easy fix.
Thank you for your time.
Chris Gervais
GeoserverError.txt (18 KB)
