Is it possible to somehow get a WMS GetLegendGraphic back that has some transparency?
Thanks!
Steve Ferguson
Thanks!
Steve Ferguson
On Mon, Oct 19, 2015 at 8:30 PM, Ferguson, Steve -FS <sferguson@anonymised.com>
transparency?
Have you tried requesting it in PNG format, and adding &transparent=true to
the request?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks for the response. Yes, I have tried this. The image remains non-transparent with a white background.
Thank you for any other suggestions.
Steve
On Mon, Oct 19, 2015 at 8:30 PM, Ferguson, Steve -FS <sferguson@…102…> wrote:
Have you tried requesting it in PNG format, and adding &transparent=true to the request?
Ing. Andrea Aime
@geowolf
Technical Lead
I was only able to make a layer transparent when I edited its style. Passing transparent=true in the link had no effects.
JJ.
From: Ferguson, Steve -FS [mailto:sferguson@anonymised.com]
Sent: Tuesday, October 20, 2015 7:13 AM
To: Andrea Aime andrea.aime@anonymised.com
Cc: geoserver-users@anonymised.comeforge.net
Subject: Re: [Geoserver-users] Transparent GetLegendGraphic WMS request?
Steve
From: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com] On Behalf Of Andrea Aime
Sent: Tuesday, October 20, 2015 5:23 AM
To: Ferguson, Steve -FS
On Mon, Oct 19, 2015 at 8:30 PM, Ferguson, Steve -FS <sferguson@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
