[Geoserver-users] Trouble Adding a CoverageStore
Hi All,
Just wondering if anyone can help. I'm trying to add a geotiff
CoverageStore to Geoserver, but on clicking Submit, I get the following
error:
GeoServer - Exception
The following exception was thrown:
org.opengis.parameter.ParameterNotFoundException: Parameter
"latitude_of_origin" is missing.
However, when I examine the image using gdalinfo, it seems that the
latitude_of_origin does seem to be present:
PROJCS["unnamed",
    GEOGCS["WGS 84",
        DATUM["WGS_1984",
            SPHEROID["WGS 84",6378137,298.2572235629972,
                AUTHORITY["EPSG","7030"]],
            AUTHORITY["EPSG","6326"]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433],
        AUTHORITY["EPSG","4326"]],
    PROJECTION["Equirectangular"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",0],
    PARAMETER["false_easting",0],
    PARAMETER["false_northing",0],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]]]
If it helps, I can post the image and the geoserver URL for people to try.
But just thought I'd give the above first, in case there's an obvious
answer.
Any advice would be much appreciated.
Many thanks,
Andy
View this message in context: http://www.nabble.com/Trouble-Adding-a-CoverageStore-tf4237876.html#a12058038
andyjc wrote:
Hi All,
error:
PROJCS["unnamed",
    GEOGCS["WGS 84",
        DATUM["WGS_1984",
    UNIT["metre",1,
answer.
Many thanks,
Andy
Hmmm... it may be that the latitude of origin is not specified an GADL copes
with it by providing
a default. Can you post a link to the data so that we can try it out?
View this message in context: http://www.nabble.com/Trouble-Adding-a-CoverageStore-tf4237876.html#a12070116
Hi Andrea,
Thanks for getting back. The geoserver instance is
http://81.29.77.204:8080/geoserver here (still with default login details),
and the geotiff I'm trying to add is
http://81.29.77.204/MET8-FC-070807-1145.tif here . The local URL (used on
the Coverage Data Set Editor) is:
file:coverages/meteosat/MET8-FC-070807-1145.tif
Andy
aaime wrote:
andyjc wrote:
Hi All,
error:
PROJCS["unnamed",
    GEOGCS["WGS 84",
        DATUM["WGS_1984",
    UNIT["metre",1,
try. But just thought I'd give the above first, in case there's an
obvious answer.
Many thanks,
Andy
copes with it by providing
View this message in context: http://www.nabble.com/Trouble-Adding-a-CoverageStore-tf4237876.html#a12070603
Ciao,
From the error you are getting I suspect this might be a bug of the geotiff
reader. I lately added support for the latitude_of_origin parameter for
projections but I suspect that something got messed. Tomorrow I should be
working on some related parts of geotools-geoserver hence I will try do some
testing with your data and I'll try to fix the issue if one exists!
Simone.
Eng. Simone Giannecchini
President /CEO GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
-----Original Message-----
From: geoserver-users-bounces@lists.sourceforge.net
[mailto:geoserver-users-bounces@lists.sourceforge.net] On Behalf Of andyjc
Sent: giovedì 9 agosto 2007 13.17
Subject: Re: [Geoserver-users] Trouble Adding a CoverageStore
Hi Andrea,
Andy
aaime wrote:
andyjc wrote:
Hi All,
error:
PROJCS["unnamed",
    GEOGCS["WGS 84",
        DATUM["WGS_1984",
    UNIT["metre",1,
obvious answer.
Many thanks,
Andy
3
Geoserver-users mailing list
I investigated this issue deeply, here you have the results.
The CRS of the geotiff is as follows:
PROJCS["unnamed",
    GEOGCS["WGS 84",
        DATUM["WGS_1984",
            SPHEROID["WGS 84",6378137,298.2572235630016,
    UNIT["metre",1,
All the problems are geotools related.
In the right order:
1> GeoTools implements the Equirectangular projection as an Alias of the
EquidistantCylindrical or better of the PlateCarre projection (which is in
turn an alias for EquidistantCylindrical where code standard_parallel_1 is
0°. First problem is that GeoTools implementations always expect
standard_parallel_1 instead of latitude_of_origin as reported by the
unofficial list of projections here:
http://remotesensing.org/geotiff/proj_list/equirectangular.html
Now, Martin, how would you behave here? Would simply change the parameter
name from latitude_of_origin to standard_parallel_1 when creating the
parameters for the transform? Should we use an alias?
Note that this impact greatly the way I load and initialize the parameters
inside the geotiff plugin.
2>GeoTools referencing package do not implement elliptical
EquidistantCylindrical projections hence even if problem 1 did not exist we
would not be able to support this geotiff yet.
Conclusion.
The problem could be fixed pretty easily. I am waiting for some directions
from Martin for 1 while I am going to open a Jira task for 2 and fix it
myself next days.
Ciao,
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Hi Andrea,
Andy
aaime wrote:
andyjc wrote:
Hi All,
error:
PROJCS["unnamed",
    GEOGCS["WGS 84",
        DATUM["WGS_1984",
    UNIT["metre",1,
obvious answer.
Many thanks,
Andy
3
According the comment in EquidistantCylindrical:
* "standard_parallel_1" is used by ESRI and Synder
* "latitude_of_origin" is used by EPSG and remotesensing.org
I will add alias on the 2.4 branch.
We didn't found any indication on the web about ellipsical
EquidistantCylindrical. If someone has some guidance about what should be the
appropriate calculation, we could add it.
  Martin
I forgot to said: we already have a JIRA for that:
http://jira.codehaus.org/browse/GEOT-1182
  Martin
Hi guys,
I have been sneaking around a bit in order to understand who to fix
this problem.
During my jouorney I ran into this sentences on one of the USGS
various projects (specifically this one ):
"Now ISIS, as with most applications, only uses a spherical equation
(drops the semi-minor) for Simple Cylindrical and since the center lat
is hard-wired as 0, then the radius used will be the semi-major
radius."
What do yuo guys think is this the best behvaiour we should implement
in GeoTools as well? we should just drop the semi-minor axis?
Ciao,
Simone.
       Martin
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
mob: +39 349 8227000
