[Geoserver-users] Trouble getting GDAL Extension to work
I'm trying to enable some extra features on our geoserver, such as ECW
raster formats through GDAL extension.
I followed (in my opinion...) carefully the following documentation :
http://docs.geoserver.org/stable/en/user/data/raster/gdal.html
In the status page of geoserver (version 2.3.2), i have :
Native JAI true
Disponibilité du JAI ImageIO true
Mémoire maximale pour le JAI 503 MB
Geoserver runs on Debian amd64 with a tomcat 7 and a JVM of the
following version :
Oracle Corporation: 1.7.0_25 (Java HotSpot(TM) 64-Bit Server VM)
How can I check my installation ? And what could have failed ?
Thanks for your help.
Emmanuel Lesouef
Hi Emmanuel,
please read below...
On Wed, Jul 3, 2013 at 3:16 PM, Emmanuel Lesouef <e.lesouef@anonymised.com> wrote:
I suppose you have purchased an ECW license (which is mandatory to use it
in a Server).
Native JAI true
following version :
Did you already try the gdalinfo command provided with the download? It
will use the JAVA bindings so you can check whether that part is working
standalone at least.
Once done, if everything has been properly configured (the libraries are on
LD_LIBRARY_PATH) you should see additional coverage stores from the add
stores section of GeoServer.
I'm not sure about which kind of issues you have. Do you have some
error/logs to report?
Daniele
Emmanuel Lesouef
This SF.net email is sponsored by Windows:
Build for Windows Store.
http://p.sf.net/sfu/windows-dev2dev
Geoserver-users mailing list
Hi Emmanuel,
you could check if the “Raster Data Sources” has been created in the “store” section.
I also remind you that gdal libraries don’t support ECW format natively: you need an ECW license.
cheers
Michele
I’m trying to enable some extra features on our geoserver, such as ECW
I followed (in my opinion…) carefully the following documentation :
Native JAI true
following version :
Oracle Corporation: 1.7.0_25 (Java HotSpot™ 64-Bit Server VM)
Emmanuel Lesouef
Thanks for answering Daniele.
My answers inline.
Le Wed, 3 Jul 2013 15:58:57 +0200,
Daniele Romagnoli <daniele.romagnoli@anonymised.com> a écrit :
Hi Emmanuel,
wrote:
> Hi,
> ECW raster formats through GDAL extension.
use it in a Server).
Yep. Just checked with our GIS service. We have it :wink:
> documentation :
> Native JAI true
> following version :
Just saw it :
root@anonymised.com:/usr/local/lib# ./gdalinfo
./gdalinfo: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /usr/local/lib/libgdal.so.1)
./gdalinfo: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /usr/local/lib/libNCSEcw.so.0)
./gdalinfo: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /usr/local/lib/libNCSCnet.so.0)
./gdalinfo: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /usr/local/lib/libNCSUtil.so.0)
Unfortunately :
root@anonymised.com:/usr/local/lib# ls -al /lib/x86_64-linux-gnu/libc.so.6
lrwxrwxrwx 1 root root 12 déc. 30 2012 /lib/x86_64-linux-gnu/libc.so.6 -> libc-2.13.so
Should I consider Debian 7 as incompatible ?
It will use the JAVA bindings so you can check whether that part is
working standalone at least.
are on LD_LIBRARY_PATH) you should see additional coverage stores
from the add stores section of GeoServer.
Thanks for your help, really appreciated. Thanks to Michele also.
Emmanuel Lesouef
Hi Emmanuel,
You are not the first one having a similar issue… Each linux distribution/version seems having a different set of installed libc libraries and versions…
This is why we have added Centos and Ubuntu prefixes (as well with version number) to the available downloads since we have created those set of libs on those set of environments.
You may consider building it by yourself on your system so that the created native libs will surely match the underlying low level libs (libc and required dependencies).
You may take some hints from the setupGuide we have setup long time ago (before providing native libs available for download).
https://java.net/downloads/imageio-ext/Documentation/ImageioExt-SetupGuide-1.1.pdf
In your case, you should consider checking sections 3.6 3.7.1.3 3.7.2 3.7.2.3 3.7.3.
Note that this document has been made on top of an older GDAL version (1.7.3) so you should consider updating references (links and downloads) to 1.9.2 instead.
Hope this helps.
Daniele
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
On Wed, Jul 3, 2013 at 5:24 PM, Emmanuel Lesouef <e.lesouef@anonymised.com> wrote:
My answers inline.
Hi Emmanuel,
please read below…
wrote:
documentation :
Native JAI true
following version :
Just saw it :
./gdalinfo: /lib/x86_64-linux-gnu/libc.so.6: version GLIBC_2.14' not found (required by /usr/local/lib/libgdal.so.1) ./gdalinfo: /lib/x86_64-linux-gnu/libc.so.6: version GLIBC_2.14’ not found (required by /usr/local/lib/libNCSEcw.so.0)
./gdalinfo: /lib/x86_64-linux-gnu/libc.so.6: version GLIBC_2.14' not found (required by /usr/local/lib/libNCSCnet.so.0) ./gdalinfo: /lib/x86_64-linux-gnu/libc.so.6: version GLIBC_2.14’ not found (required by /usr/local/lib/libNCSUtil.so.0)
Unfortunately :
lrwxrwxrwx 1 root root 12 déc. 30 2012 /lib/x86_64-linux-gnu/libc.so.6 → libc-2.13.so
Emmanuel Lesouef
It seems that the source code needed to build the ECW libs is no longer
unavailable.
Is anybody aware of a location where they could be downloaded ?
Thanks in advance.
Le Wed, 3 Jul 2013 17:36:47 +0200,
Hi Emmanuel,
You are not the first one having a similar issue... Each linux
libraries and versions...
Hope this helps.
Daniele
Emmanuel Lesouef
CRBN/DSI/SITI
t: 0231069671
e: e.lesouef@anonymised.com
Hi Emmanuel,
I have the impression that you need the ECW SDK library named “libecwj2” that you should find in the ERDAS packages or here:
http://geospatial.intergraph.com/products/other/ecw/ERDASECWJPEG2000SDK/Details.aspx
Once you have got it you should compile the gdal libraries with ECW support.Here a little how-to:
http://trac.osgeo.org/gdal/wiki/ECW
Michele
On Thu, Jul 4, 2013 at 4:03 PM, Emmanuel Lesouef <e.lesouef@anonymised.com> wrote:
unavailable.
Thanks in advance.
Hi Emmanuel,
Hope this helps.
Daniele
Emmanuel Lesouef
CRBN/DSI/SITI
t: 0231069671
