[Geoserver-users] Trouble getting maps to show up in GeoServer
Since starting to use GeoServer, I have been having an issue with not being able to get anything to show up in the openLayers tab. I know that there is something there because when I click on the map space the attributes come up at the bottom. Have tried different browsers, but no luck yet with getting the map items to show up. Any help on this would be greatly appreciated. Thank you.
Michael Pratten | GIS Analyst II
Tetra Tech, Inc. | Complex World, Clear Solutions™
20251 Century Blvd., Suite 200, Germantown, MD 20874 -7114
Direct Line: 301.528.3050| Fax 301.528.3000
michael.pratten@anonymised.com
www.tetratech.com
PLEASE NOTE: This message, including any attachments, may include privileged, confidential and/or inside information. Any distribution or use of this communication by anyone other than the intended recipient is strictly prohibited and may be unlawful. If you are not the intended recipient, please notify the sender by replying to this message and then delete it from your system.
I assume you are meaning in the map preview. Click on the options control (top right above the pan arrows). Try change from single tile to tiled and fiddling with zoom.
Notice: This email and any attachments are confidential.
If received in error please destroy and immediately notify us.
Do not copy or disclose the contents.
