When I tried to shut down geoserver using $GEOSERVER_HOME/bin/shutdown.sh, I get this:
The GEOSERVER_HOME environment variable is not defined correctly
This environment variable is needed to run this program
I'm sure that the variable has been set (otherwise it won't even run...), does anyone else had this problem? I'm using version 1.5.1 btw.
Doris
hello Doris,
On Friday 27 July 2007 09:43:49 dlamoris@anonymised.com wrote:
btw.
we also use version 1.5.1 and we adjusted the script as attached --just
make sure you edit the STOP.PORT value to suit your environment which
for the default installation would be 8005.
it's probably also worth while checking the latest version of GeoServer
1.5.x. the version of this script there may have already been fixed
but i haven't tried it.
cheers;
rsn
shutdown.sh (2.18 KB)
Raif S. Naffah wrote:
hello Doris,
btw.
we also use version 1.5.1 and we adjusted the script as attached --just make sure you edit the STOP.PORT value to suit your environment which for the default installation would be 8005.
it's probably also worth while checking the latest version of GeoServer 1.5.x. the version of this script there may have already been fixed but i haven't tried it.
Yup, the script has been fixed and should be a-ok for the 1.5.2 release. If someone could verify via a recent 1.5.x nightly build that would be great.
-Justin
cheers;
rsn
!DSPAM:4007,46a936f6182207082231907!
Geoserver-users mailing list
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
