Ok, I'll check this , but the arcSDE connector works fine with geoserver 1.4.x branch (same arcSDE DB)
It seems that some improvements have been done for 1.5.x & 1.6.x version.
Mikael
-----Ursprungligt meddelande-----
Från: Saul Farber [mailto:Saul.Farber@anonymised.com]
Skickat: den 16 november 2007 08:45
Till: Hamström Mikael
Kopia: Geoserver-users@lists.sourceforge.net
Ämne: Re: [Geoserver-users] Trouble with arcsde datastore and 1.6.0 rc1
It's quite likely that there's a field in your ArcSDE table that isn't supported by the current ArcSDE plugin.
What data-types are each of the columns in your ArcSDE table? Note that I'm asking what ArcSDE datatype they are (STRING is different from NSTRING, etc). Do you have an XML metadata column in there?
This bit of code should also give a better error to you, for sure!
Sorry about that.
--saul
On Fri, 2007-11-16 at 08:34 +0100, Hamström Mikael wrote:
Hi.
In geoserver .16.0 rc 1 following trace come up when I tried to add a
new feature type.Any idea to solve this ?
Regards / Mikael
HTTP ERROR: 500
NONE
RequestURI=/geoserver/config/data/typeNewSubmit.do
Caused by:
java.lang.NoSuchFieldError: NONE
at
org.geotools.data.arcsde.ArcSDEAdapter.createAttributeTypes(ArcSDEAdapter.java:418)
at
org.geotools.data.arcsde.ArcSDEAdapter.fetchSchema(ArcSDEAdapter.java:287)
at
org.geotools.data.arcsde.ArcSDEDataStore.getSchema(ArcSDEDataStore.java:202)
at
org.vfny.geoserver.action.data.DataFeatureTypesNewAction.execute(DataFeatureTypesNewAction.java:84)
at
org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
at
org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
at
org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
at
org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
at
org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
at
javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
at
javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
at
org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:459)
at org.mortbay.jetty.servlet.ServletHandler
$CachedChain.doFilter(ServletHandler.java:1054)
at org.acegisecurity.util.FilterChainProxy
$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at
org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at
org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at
org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
at
org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFi
lter(SecurityContextHolderAwareRequestFilter.java:81)at org.acegisecurity.util.FilterChainProxy
at
org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217)
at
org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106)
at
org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter
(HttpSessionContextIntegrationFilter.java:229)at org.acegisecurity.util.FilterChainProxy
at
org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at
org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
$CachedChain.doFilter(ServletHandler.java:1045)
at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:358)
at
org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:231)
at
org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:629)
at
org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:453)
at
org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:149)
at
org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:123)
at
org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:141)
at org.mortbay.jetty.Server.handle(Server.java:303)
at
org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:452)
at org.mortbay.jetty.HttpConnection
$RequestHandler.content(HttpConnection.java:735)
at
org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:636)
at
org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:203)
at
org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:349)
at
org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:320)
at org.mortbay.thread.BoundedThreadPool
$PoolThread.run(BoundedThreadPool.java:475)
Powered by Jetty://--------------------------------------------------------------------
Mikael HamströmSMHI
601 76 Norrköping
+46 11 495 8539
mailto:mikael.hamstrom@anonymised.com----------------------------------------------------------------------
--- This SF.net email is sponsored by: Microsoft Defy all challenges.
Microsoft(R) Visual Studio 2005.
_______________________________________________ Geoserver-users mailing list Geoserver-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-users
