Hello.
1) Layer *L* was created - Image Mosaic from .tif files.
2) Layer group *LG* was created and *L* added to it.
3) When viewing the layer there is a spot where layer is blank although
there should be images. I have openend .tif file and checked, the marked are
is blank http://prntscr.com/fr34ty.
Geoserver provides following messages:
/2017-07-03 16:24:50,048 WARN [lite.gridcoverage2d] - Could not reduce the
grid geometry inside the valid area bounds:
ReferencedEnvelope[-21.0 : 69.0, -90.0 : 90.0] Grid geometry
isGridGeometry2D[GridEnvelope2D[35013..37139, 40792..42918],
PARAM_MT["Affine", PARAMETER["num_row", 3], PARAMETER["num_col", 3],
PARAMETER["elt_0_0", 2.75], PARAMETER["elt_0_2", 475001.375],
PARAMETER["elt_1_1", -2.75], PARAMETER["elt_1_2", 6259998.625]]]
2017-07-03 16:24:50,171 WARN [gdal.BaseGDALGridCoverage2DReader] - Using
default coordinate reference system
2017-07-03 16:24:50,188 WARN [coverageio.gdal] - Not all the values were
found for this world file!
org.geotools.data.DataSourceException: Not all the values were found for
this world file! at
org.geotools.data.WorldFileReader.parseWorldFile(WorldFileReader.java:231)
at org.geotools.data.WorldFileReader.<init>(WorldFileReader.java:128) at
org.geotools.data.WorldFileReader.<init>(WorldFileReader.java:110)/
What is the problem?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Trouble-with-Image-Mosaic-tif-tp5326504.html
It looks like you have a broken world file - can you find the world file for that tiff and check it?
Ian
On 3 July 2017 at 14:51, user154654 via Geoserver-users <geoserver-users@lists.sourceforge.net> wrote:
Hello.
- Layer L was created - Image Mosaic from .tif files.
- Layer group LG was created and L added to it.
- When viewing the layer there is a spot where layer is blank although
isGridGeometry2D[GridEnvelope2D[35013…37139, 40792…42918],
PARAM_MT[“Affine”, PARAMETER[“num_row”, 3], PARAMETER[“num_col”, 3],
PARAMETER[“elt_0_0”, 2.75], PARAMETER[“elt_0_2”, 475001.375],
PARAMETER[“elt_1_1”, -2.75], PARAMETER[“elt_1_2”, 6259998.625]]]
this world file! at
at org.geotools.data.WorldFileReader.(WorldFileReader.java:128) at
org.geotools.data.WorldFileReader.(WorldFileReader.java:110)/
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
Geoserver-users@anonymised.com.382…sourceforge.net
Ian Turton
Hi, how would I validate this file?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Trouble-with-Image-Mosaic-tif-tp5326504p5326572.html
Validation does not work with env function, but if you send de style directly to geoserver without validation it works.
In fact, the same file with type=“values” allows the previsualization of the legend, but not with type=“intervals”.
Regards
Jose
El 5 jul. 2017 1:39, “user154654 via Geoserver-users” <geoserver-users@lists.sourceforge.net> escribió:
Yeah,
I’m guessing that when the env function integration was added, legend generation was not
updated to consider the possibility of expressions in the colormap entries.
Can anyone open a ticket with an example style? Seems like a good candidate for the
monthly bug fix code sprint
On Wed, Jul 5, 2017 at 7:55 AM, Jose Antonio <islaperejil@anonymised.com> wrote:
Regards
Jose
El 5 jul. 2017 1:39, “user154654 via Geoserver-users” <geoserver-users@anonymised.comsourceforge.net> escribió:
Geoserver-users@anonymised.comrge.net
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
This article gives you the definition - https://en.wikipedia.org/wiki/World_file basically look for files with less than 6 lines
Ian
On 4 July 2017 at 07:01, user154654 via Geoserver-users <geoserver-users@lists.sourceforge.net> wrote:
Ian Turton
This matter is temporary set aside, will let you know how it went.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Trouble-with-Image-Mosaic-tif-tp5326504p5327254.html
Problem was that tiff files were overlapping so I had to move overlapping
tiffs to different layers and create a layer group.
Since I was checking logs on production onvironment I guess I misjudged time
of my GetMap requests or there was actualy a bad layer /bellow/ the tiff
layer and that is why I "connected" those warnings with blank areas.
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoServer-User-f3786390.html
we use overalapping TIFFs all the time (satellite images do overlap a lot)
without any such issue, but it requires setting transparency/nodata/footprint
so that the parts of the file that do not have valid pixels are ignored
On Tue, Sep 26, 2017 at 1:39 PM, user154654 via Geoserver-users <geoserver-users@lists.sourceforge.net> wrote:
layer and that is why I “connected” those warnings with blank areas.
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
