[Geoserver-users] Trouble with simple setup of Image Mosaic over a working GRIB2 file
Greetings,
I am attempting to setup a time based image mosaic over a series of GRIB2 files. Setup of a GRIB store with the file succeeds with no issues, and allows me to visualize the contents in geoserver. When I put the same GRIB in a directory, and attempt to create an image mosaic from it, it fails. I’ve tried just pointing image mosaic at the directory where the GRIB sits with no additional files, and it fails. I’ve tried also with a datastore.properties, indexer.xml, and _auxiliary.xml and this also fails. I am at my wits end trying to get this going with image mosaic.
This is the file I am attempting :
http://nomads.ncep.noaa.gov/cgi-bin/filter_hiresconus.pl?file=hiresw.t00z.arw_5km.f00.conus.grib2&all_lev=on&var_TMP=on&leftlon=0&rightlon=360&toplat=90&bottomlat=-90&dir=%2Fhiresw.20160809
my indexer.xml looks like this :
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
time
the_geom:Polygon,imageindex:Integer,time:java.util.Date
Temperature_surface
Temperature_surface
My _auxiliary.xml looks like :
Temperature_surface
Temperature_surface
My datastore.properties contains details to connect to postgres, this has worked fine with other stores so I trust it.
The latest error I get is :
09 Aug 21:34:10 ERROR [imagemosaic.Utils] - Invalid mosaic schema SimpleFeatureTypeImpl Temperature_surface identified extends Feature(the_geom:the_geom,imageindex:imageindex,time:time), it should have a geometry and a location property of name null
java.lang.IllegalArgumentException: Invalid mosaic schema SimpleFeatureTypeImpl Temperature_surface identified extends Feature(the_geom:the_geom,imageindex:imageindex,time:time), it should have a geometry and a location property of name null
at org.geotools.gce.imagemosaic.catalog.GTDataStoreGranuleCatalog.checkMosaicSchema(GTDataStoreGranuleCatalog.java:284)
at org.geotools.gce.imagemosaic.catalog.GTDataStoreGranuleCatalog.createType(GTDataStoreGranuleCatalog.java:617)
at org.geotools.gce.imagemosaic.catalog.CachingDataStoreGranuleCatalog.createType(CachingDataStoreGranuleCatalog.java:104)
at org.geotools.gce.imagemosaic.RasterManager.createStore(RasterManager.java:1283)
at org.geotools.gce.imagemosaic.ImageMosaicReader.createCoverage(ImageMosaicReader.java:1129)
at org.geotools.gce.imagemosaic.ImageMosaicConfigHandler.updateConfiguration(ImageMosaicConfigHandler.java:880)
at org.geotools.gce.imagemosaic.ImageMosaicWalker.handleFile(ImageMosaicWalker.java:210)
at org.geotools.gce.imagemosaic.ImageMosaicDirectoryWalker$MosaicDirectoryWalker.handleFile(ImageMosaicDirectoryWalker.java:98)
at org.apache.commons.io.DirectoryWalker.walk(DirectoryWalker.java:367)
at org.apache.commons.io.DirectoryWalker.walk(DirectoryWalker.java:335)
at org.geotools.gce.imagemosaic.ImageMosaicDirectoryWalker$MosaicDirectoryWalker.(ImageMosaicDirectoryWalker.java:114)
at org.geotools.gce.imagemosaic.ImageMosaicDirectoryWalker.run(ImageMosaicDirectoryWalker.java:196)
at org.geotools.gce.imagemosaic.Utils.createMosaic(Utils.java:363)
Any help or advice would be greatly appreciated, I am uncertain how to resolve this.
Thanks!
cid:image001.jpg@anonymised.com
Steve Ferguson
Senior Software Systems Engineer
Forest Service Contractor
Digital Visions Enterprise Team
p: 919-999-4930 (PST)
sferguson@anonymised.com
cid:image002.png@anonymised.com9...cid:image003.png@anonymised.comcid:image004.png@anonymised.com
Caring for the land and serving people
Steve,
I found that omitting location:String from the schema resulted in failure with an exception message similar to that you report:
java.lang.IllegalArgumentException: Invalid mosaic schema SimpleFeatureTypeImpl Pressure_surface identified extends Feature(the_geom:the_geom,imageindex:imageindex,time:time), it should have a geometry and a location property of name null
I found that it was necessary to use a schema like this:
<attributes>the_geom:Polygon,location:String,imageindex:Integer,time:java.util.Date</attributes>
See:
https://github.com/bencaradocdavies/geoserver/wiki/RAP-Native-Grid-ImageMosaic
Kind regards,
Ben.
On 10/08/16 09:52, Ferguson, Steve -FS wrote:
Greetings,
I am attempting to setup a time based image mosaic over a series of GRIB2 files. Setup of a GRIB store with the file succeeds with no issues, and allows me to visualize the contents in geoserver. When I put the same GRIB in a directory, and attempt to create an image mosaic from it, it fails. I've tried just pointing image mosaic at the directory where the GRIB sits with no additional files, and it fails. I've tried also with a datastore.properties, indexer.xml, and _auxiliary.xml and this also fails. I am at my wits end trying to get this going with image mosaic.
<Indexer>
  <domains>
    <domain name="time">
      <attributes><attribute>time</attribute></attributes>
    </domain>
  </domains>
    <coverages>
        <coverage>
            <schema name="Temperature_surface">
                <attributes>the_geom:Polygon,imageindex:Integer,time:java.util.Date</attributes>
            </schema>
      <domains>
        <domain ref="time" />
      </domains>
            <origName>Temperature_surface</origName>
            <name>Temperature_surface</name>
        </coverage>
    </coverages>
  <parameters>
    <parameter name="AuxiliaryFile" value="/gdata/grib/nomads_img/_auxiliary.xml" />
    <parameter name="AbsolutePath" value="true" />
  </parameters>
</Indexer>
<?xml version="1.0" encoding="UTF-8"?><Indexer>
  <coverages>
    <coverage>
      </schema>
    </coverage>
  </coverages>
</Indexer>
        at org.geotools.gce.imagemosaic.ImageMosaicDirectoryWalker$MosaicDirectoryWalker.<init>(ImageMosaicDirectoryWalker.java:114)
Thanks!
[cid:image001.jpg@anonymised.com]
Steve Ferguson
sferguson@anonymised.com<mailto:sferguson@anonymised.com>
[cid:image002.png@anonymised.com]<http://usda.gov/&gt;\[cid:image003\.png@anonymised\.com\]&lt;https://twitter.com/forestservice&gt;\[cid:image004\.png@anonymised\.com\]&lt;http://facebook.com/USDA&gt;
This electronic message contains information generated by the USDA solely for the intended recipients. Any unauthorized interception of this message or the use or disclosure of the information it contains may violate the law and subject the violator to civil or criminal penalties. If you believe you have received this message in error, please notify the sender and delete the email immediately.
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning reports. http://sdm.link/zohodev2dev
Geoserver-users mailing list
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
Ben, that worked! Thank you so much!
Steve
-----Original Message-----
Sent: Tuesday, August 09, 2016 3:45 PM
To: Ferguson, Steve -FS <sferguson@...102...>; geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] Trouble with simple setup of Image Mosaic over a working GRIB2 file
Steve,
See:
Kind regards,
Ben.
Greetings,
<?xml version="1.0" encoding="UTF-8" standalone="yes"?> <Indexer>
  <domains>
    </domain>
  </domains>
    <coverages>
        <coverage>
            </schema>
      <domains>
      </domains>
        </coverage>
    </coverages>
  <parameters>
  </parameters>
</Indexer>
  <coverages>
    <coverage>
      </schema>
    </coverage>
  </coverages>
</Indexer>
        at
Thanks!
[cid:image001.jpg@...7759...]
Steve Ferguson
sferguson@...102...<mailto:sferguson@…102…>
[cid:image002.png@...7759...]<http://usda.gov/&gt;\[cid:image003.pn
g@...7759...]<https://twitter.com/forestservice&gt;\[cid:image004.p
ng@...7759...]<http://facebook.com/USDA&gt;
-------- What NetFlow Analyzer can do for you? Monitors network
bandwidth and traffic patterns at an interface-level. Reveals which
users, apps, and protocols are consuming the most bandwidth. Provides
multi-vendor support for NetFlow, J-Flow, sFlow and other flows. Make
informed decisions using capacity planning reports.
Ben Caradoc-Davies <ben@...6881...>
Director
Transient Software Limited <http://transient.nz/&gt; New Zealand
