Yeah, I have pointed out to them that the server isn’t compliant. Think they might have put it in the too hard basket. Thanks Andrea…
On Mon, Jul 31, 2017 at 6:01 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Duncan,
the server is not compliant, the OGC specs state clearly that parameter keys are case insensitive,
in all protocols with KVP bindings (like WMS).
As a result, there is no way to control the parameters key case, because it’s not meant to matter
(that said, I guess it can be made so with some coding).
On Mon, Jul 31, 2017 at 9:23 AM, Duncan Sayers <duncansayers@anonymised.com> wrote:
I’m trying to setup geoserver (2.11.1) to cascade a remote WMS. When I attempt this I get an error:
Connection test failed: Server returned HTTP response code: 401 for URL: https://xxxx/wms?REQUEST=GetCapabilities&SERVICE=WMS…etc.
Turns out that the server I’m connecting to insists on lower case parameter names in the URL. I setup the Capabilities URL in the Connection Info configuration to use a URL with lower case parameter names. However the Connection test error (above) displays uppercase for all parameter names i.e. request=GetCapabilities gets shifted to REQUEST=GetCapabilities, which then gets rejected by the other end.
The long and the short of it…Is it true that geoserver makes uppercase the parameter names? If so, is it configurable not to do so?
Duncan
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
Geoserver-users@anonymised.comrge.net
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
