[Geoserver-users] Trying to hook up Oracle
Hello,
I am trying to get GeoServer 1.6.2 to use an Oracale server, but can't
get the connection to work.
On the GeoServer console I found this:
form connection params { schema="", port="1521", passwd="user1",
dbtype="oracle ", host="ORA11G", instance="ORCL", user="user1"}
21 Apr 10:47:24 WARN [geotools.data] - Could not acquire Oracle
Spatial Database :java.lang.NoClassDefFoundError:
org/geotools/geometry/JTS$ReferencedEnvelope
org/geotools/geometry/JTS$ReferencedEnvelope at
org.geotools.data.oracle.OracleDataStoreFactory.createDataStore(OracleDataStoreFactory.java:177)
        at org.geotools.data.DataStoreFinder.getDataStore(DataStoreFinder.java:9
1)
        at org.vfny.geoserver.util.DataStoreUtils.getDataStore(DataStoreUtils.ja
va:62)
        at org.vfny.geoserver.util.DataStoreUtils.acquireDataStore(DataStoreUtil
s.java:51)
        at org.vfny.geoserver.action.data.DataDataStoresEditorAction.execute(Dat
aDataStoresEditorAction.java:134)
        at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
I suspect I am missing a component.
Any ideas on what is going wrong? I am able to connect to the Oracle
server with other utilities.
Thanks.
CB ha scritto:
Hello,
This error message seems to suggest a mismatch between GeoServer
and the Oracle datastore plugin you are using.
You cannot use an oracle plugin for, say, 1.5.3 in 1.6.2, the
GeoTools API changed in the meantime in a binary incompatible
way.
Please clean up you GeoServer installation, download the Oracle
extension for GeoServer 1.6.2 and try again.
I believe many new users are having troubles, because the natural link from
http://geoserver.org/display/GEOSDOC/Oracle+DataStore
is leading to here http://prdownloads.sourceforge.net/geoserver/geoserver-1.3.x-oracle-ext.zip?download
and that version will not work if I have understood it right.
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: geoserver-users-bounces@lists.sourceforge.net
[mailto:geoserver-users-bounces@lists.sourceforge.net]
Puolesta Andrea Aime
Lähetetty: 22. huhtikuuta 2008 9:46
Vastaanottaja: CB
Kopio: Geoserver-users@lists.sourceforge.net
Aihe: Re: [Geoserver-users] Trying to hook up Oracle
CB ha scritto:
> Hello,
server, but can't
GeoServer and the Oracle datastore plugin you are using.
GeoTools API changed in the meantime in a binary incompatible way.
Oracle extension for GeoServer 1.6.2 and try again.
This SF.net email is sponsored by the 2008 JavaOne(SM)
Conference Don't miss this year's exciting event. There's
still time to save $100.
Use priority code J8TL2D2.
http://ad.doubleclick.net/clk;198757673;13503038;p?http://java
.sun.com/javaone
Geoserver-users mailing list
Rahkonen Jukka ha scritto:
I believe many new users are having troubles, because the natural link from http://geoserver.org/display/GEOSDOC/Oracle+DataStore
Ah, right, you're absolutely right. I fixed the link, but noticed the page has some other outdated information (e.g., we do include the jdbc
driver in the download as far as I know).
I've scheduled an issue to fix this since atm I cannot work on it:
http://jira.codehaus.org/browse/GEOS-1879
> Hi,
Thanks, everyone. It seems to have been a version mismatch. Appears
to be working now.
CB
