[Geoserver-users] Tutorial / Resources for setting up a REST API Client
I am currently trying to set up API Access to a geoserver server. I would like to use a separate user and role with limited access to avoid giving the API client admin access. The idea is to automatically upload new data and make it available using a script that I am currently developing.
Is there a proper way or a howto that I can follow? Googling only directs me to setups that seem to be unsafe like assigning the Admin role.
Simon
You can set the user up in the normal way (https://docs.geoserver.org/latest/en/user/security/index.html#security) and give them write permissions to any or all workspaces
Ian
ยทยทยท
Ian Turton
Dear Ian,
I have set up a Filter "Credentials From Request Headers" and added it to the rest filter chain. For some reason the Filter gets removed from the rest filter chain after returning to the settings after a few minutes. I am not sure what triggers this.
How can I make this setting persist?
The user has the role "DEPLOY_API_ROLE", which is added to security/rest.properties:
/rest/workspaces/**;GET,POST,DELETE,PUT=DEPLOY_API_ROLE
I tried to access the API using python requests library:
   result = requests.get(
     api_endpoint + "/workspaces/climate/datastores",
     headers={
       "X-Credentials" : "private-user=" + api_username,
       "X-Credentials" : "private-pw=" + api_password,
       #"accept" : "application/xml",
       #"content-type" : "application/json",
but only receive "403 Access Denied". Probably because the Filter is removed from the settings.
Am I missing something?
Simon
Am 01.11.23 um 11:27 schrieb Ian Turton:
Ian
On Wed, 1 Nov 2023 at 10:06, Simon Michalke via Geoserver-users <geoserver-users@lists.sourceforge.net <mailto:geoserver-users@lists.sourceforge.net>> wrote:
    developing.
    role.
    Simon
    Geoserver-users mailing list
    Please make sure you read the following two resources before posting
    to this list:
    - Earning your support instead of buying it, but Ian Turton:
    http://www.ianturton.com/talks/foss4g.html#/
    <http://www.ianturton.com/talks/foss4g.html#/&gt;
    - The GeoServer user list posting guidelines:
    http://geoserver.org/comm/userlist-guidelines.html
    <http://geoserver.org/comm/userlist-guidelines.html&gt;
    If you want to request a feature or an improvement, also see this:
    https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
    <mailto:Geoserver-users@lists.sourceforge.net>
    <https://lists.sourceforge.net/lists/listinfo/geoserver-users&gt;
Ian Turton
