I tried to upload a tif file to the geoserver using geonode, and I got the the following error:
‘Unable to acquire a reader for this coverage with format: GeoTIFFjava.lang.RuntimeException: Capabilities document generation failed on coverage geonode:sld_cookbook_raster\nCapabilities document generation failed on coverage geonode:sld_cookbook_raster\nUnable to acquire a reader for this coverage with format: GeoTIFF’
Any idea? Have anyone had this issue before?
The following is the gdalinfo
Driver: GTiff/GeoTIFF
Files: …/ET/Ethiopia_2014_100m_LAEA_Landsat__BlueBand.tif
Size is 16357, 12918
Coordinate System is:
PROJCS[“unnamed”,
GEOGCS[“WGS 84”,
DATUM[“WGS_1984”,
SPHEROID[“WGS 84”,6378137,298.257223563,
AUTHORITY[“EPSG”,“7030”]],
AUTHORITY[“EPSG”,“6326”]],
PRIMEM[“Greenwich”,0],
UNIT[“degree”,0.0174532925199433],
AUTHORITY[“EPSG”,“4326”]],
PROJECTION[“Lambert_Azimuthal_Equal_Area”],
PARAMETER[“latitude_of_center”,5],
PARAMETER[“longitude_of_center”,20],
PARAMETER[“false_easting”,0],
PARAMETER[“false_northing”,0],
UNIT[“metre”,1,
AUTHORITY[“EPSG”,“9001”]]]
Origin = (1424500.000000000000000,1138500.000000000000000)
Pixel Size = (100.000000000000000,-100.000000000000000)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 1424500.000, 1138500.000) ( 33d13’54.81"E, 15d 6’40.32"N)
Lower Left ( 1424500.000, -153300.000) ( 32d50’47.46"E, 3d29’51.08"N)
Upper Right ( 3060200.000, 1138500.000) ( 48d36’ 7.15"E, 14d24’ 6.38"N)
Lower Right ( 3060200.000, -153300.000) ( 47d48’ 7.60"E, 3d 4’41.84"N)
Center ( 2242350.000, 492600.000) ( 40d29’52.14"E, 9d 4’21.74"N)
Band 1 Block=16357x1 Type=Float32, ColorInterp=Gray
NoData Value=-3.4028234663852886e+38
Best,
JC
