Hi, I'm trying to add a new featuretype based on an Oracle table in 1.5.3.
This worked fine in 1.5.2 but
now, when I try to generate the bounding box, I get the message:
The FeatureType 'NGG_OBJECT' has a NULL extent.
HINT: the dataset is empty or has no default geometry attribute.
The table has a spatial index, and contains data a mix of points and
polygons.
For another table that holds a mix of points and and line geometries there
is no problem creating a featuretype.
Rene
View this message in context: http://www.nabble.com/Unable-to-add-new-Oracle-featuretype-in-1.5.3-tf4303275.html#a12249000
