Hi All,
I cannot create a featuretype in GeoServer 1.7.3a. I use Oracle
Spatial NG datastore, which seemed to set up correctly. I also have
own namespace. When I select New on the screen
Welcome | Config | Data | FeatureTypes
I get to screen
Welcome | Config | Data | FeatureTypes | New
where I can select only existing ones. If I select one, the name is
read only, so it seems to me that editing is performed instead of
creating a new one. After removing all predefined featuretypes, the
dropdown list is empty, and if I try to hit the new button on the last
screen, an exception is thrown.
How can I create a brand new feature type with own name using own
datastore and namespace?
Thank you in advance.
Best regards: Balázs Bámer
ps: exception start like
GeoServer - Exception
The following exception was thrown:
* class java.lang.StringIndexOutOfBoundsException: String index
out of range: -1
Details:
java.lang.StringIndexOutOfBoundsException: String index out of range: -1
at java.lang.String.substring(String.java:1938)
at org.vfny.geoserver.action.data.DataFeatureTypesNewAction.execute(DataFeatureTypesNewAction.java:74)
at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
