[Geoserver-users] Unable to download GeoServer 2.15.2 Windows Installer
when trying to download the Windows Installer of GeoServer 2.15.2 SourceForge ist displaying the error message
The “/GeoServer/2.15.2/ge…geoserver-2.15.2.exe” file could not be found or is not available. Please select another file.
It seems that the file hasn’t been uploaded. Could anyone please correct this.
Thank you and best regards
Daniel Calliess
STADT:SALZBURG Magistrat, Informations- und Kommunikationstechnologie
Hubert-Sattler-Gasse 7
Postfach 63
5024 Salzburg
Tel: +43 662 8072 2776
Fax: +43 662 8072 2079
Mail: daniel.calliess@anonymised.com
http://www.stadt-salzburg.at/
Die Datenschutzerklärung und weitere Informationen finden Sie unter https://www.stadt-salzburg.at/datenschutz/
Diese E-Mail enthält vertrauliche und/oder rechtlich geschützte Informationen. Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtümlich erhalten haben, informieren Sie bitte sofort den Absender und vernichten Sie diese Mail.
We’re not currently making windows installers, sorry. We’ll try to update the pages to remove the link from the download page at sometime in the near future.
Ian
Ian Turton
The page is now updated, thanks for letting us know.
Jody Garnett
To clarify, it’s not that we’re unwilling, but we lost the build server that was used to automate Windows installer
preparation, and that the very important OSGeo cerficate on it (so no, we cannot have volunteers build the installers,
or else, they could, but they would not be signed and Windows would complain…).
A new one might get acquired, but timing is uncertain
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Thank you, Andrea, for the detailed explanation.
Regards
Daniel
Ian
On Tue, 9 Jul 2019 at 17:14, Calliess Daniel Ing. <Daniel.Calliess@…8565…> wrote:
Daniel Calliess
Postfach 63
5024 Salzburg
Mail: daniel.calliess@…8565…
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Ian Turton
Hi Andrea,
Can’t we just make an instruction on how Windows User can create their own installer for themselves (I understand you don’t want just any public user creating Windows installers for public use, but users might want to create these for private use).
I found an instruction (in the git documentation history, which explains it very nicely):
https://github.com/geoserver/geoserver/blob/b8ce783fdb2802defd7dd604d494405b16fa4533/doc/en/developer/source/release-guide/index.rst#build-windows-installer
Ronald Hoek
Application Developer
ronald.hoek@…8804…
email-groene-balk
ComponentAgro B.V.
Aston Martinlaan 70
3261 NB Oud-Beijerland
info@…8804…
0186-622 220
www.componentagro.nl
The information in this e-mail message, including any files sent with it, is exclusively intended for the addressee. Disclosure to third parties in whatever form, is only permitted with permission from ComponentAgro. If you receive this message but you are not the addressee of this e-mail, then you must permanently delete the message from your system and files.
Van: Andrea Aime <andrea.aime@…1107…>
Verzonden: dinsdag 9 juli 2019 19:16
Aan: Ian Turton <ijturton@…84…>
CC: Calliess Daniel Ing. <Daniel.Calliess@…8565…>; GeoServer Mailing List List geoserver-users@lists.sourceforge.net
Onderwerp: Re: [Geoserver-users] Unable to download GeoServer 2.15.2 Windows Installer
Ian
Daniel Calliess
Postfach 63
5024 Salzburg
Ian Turton
Hi Ronald,
indeed those are the instructions that we used years ago, when releases were still done manually.
Back then we still had developers using Windows, and we were not releasing as often as now,
so it was still manageable, but not anymore.
If I had to guess, the steps are likely still working, but only one way to know for sure :wink:
Still works exactly the way the instruction explains – even the website of NSIS is correct!
Below a screenshot of GeoServer installed using the current 2.15-SNAPSHOT and the setup files from the ‘master’ of the Git repo.
Ronald Hoek
Verzonden: vrijdag 12 juli 2019 14:00
Hi Ronald,
On Fri, Jul 12, 2019 at 1:50 PM Ronald Hoek - ComponentAgro B.V. <ronald.hoek@…8804…> wrote:
Hi Andrea,
Ronald Hoek
ronald.hoek@…8804…
email-groene-balk
ComponentAgro B.V.
Aston Martinlaan 70
info@…8804…
0186-622 220
CC: Calliess Daniel Ing. <Daniel.Calliess@…8565…>; GeoServer Mailing List List <geoserver-users@lists.sourceforge.net>
Ian
Daniel Calliess
Postfach 63
5024 Salzburg
Ian Turton
Technically one of the things that is nice about NSIS is that it is available as a linux application, so you can create an unsigned installer on linux for use on a windows machine. Sadly will all the “trust” mechanisms in place we really need a windows machine to sign the result at the end of the day…
Jody Garnett
I understand that it’s no longer possible to publish the setup file from a GeoServer perspective.
However, for those who need the Windows installer, having the instruction to let the end user create there own setup file would be nice!
Ronald Hoek
ronald.hoek@…8804…
email-groene-balk
ComponentAgro B.V.
Aston Martinlaan 70
info@…8804…
0186-622 220
Van: Jody Garnett <jody.garnett@…84…>
Verzonden: zaterdag 20 juli 2019 7:15
Aan: Ronald Hoek <ronald.hoek@…8804…>
CC: GeoServer Mailing List List geoserver-users@lists.sourceforge.net
Jody Garnett
On Fri, 12 Jul 2019 at 05:23, Ronald Hoek - ComponentAgro B.V. <ronald.hoek@…8804…> wrote:
Ronald Hoek
CC: GeoServer Mailing List List <geoserver-users@lists.sourceforge.net>
Hi Ronald,
Hi Andrea,
Ronald Hoek
ronald.hoek@…8804…
email-groene-balk
ComponentAgro B.V.
Aston Martinlaan 70
info@…8804…
0186-622 220
Ian
Daniel Calliess
Postfach 63
5024 Salzburg
Ian Turton
We have relied on the build server for so many years that the windows installer manual process isno longer in the dev guide,
but I’ve found an old copy in the version control, hopefully it still works, see here:
https://github.com/geoserver/geoserver/blob/44bacafcf1352bfe0b1836262df686fd58036585/doc/en/developer/source/release-guide/index.rst#build-windows-installer
By the way, what you get with the installer is just a “toy installation”, it’s very good for local testing
and demos, but I would never use it for production purposes, install Tomcat, optimize its JVM, add Marlin,
and deploy GeoServer in it for proper production setup instead.
Hi Andreas,
I already found the link to the old docs – thanks.
But from your point of view, there’s no longer need to add it again to the live documentation…?
If so, then I’ll add it to our own documentation, as we use GeoServer (in production) on a Windows machine only for serving WFS, with IIS as a gateway to foreward (SSL) requests to Geoserver (for which we did not setup SSL).
This works just fine for us based on the default settings supplied by the Windows Setup (running it as a Windows 32-bit service).
Note: this is not a public webservice, so the loads are not very high…
Ronald Hoek
Verzonden: maandag 12 augustus 2019 11:44
On Mon, Aug 12, 2019 at 11:37 AM Ronald Hoek - ComponentAgro B.V. <ronald.hoek@…8804…> wrote:
Ronald Hoek
ronald.hoek@…8804…
email-groene-balk
ComponentAgro B.V.
Aston Martinlaan 70
info@…8804…
0186-622 220
Jody Garnett
Ronald Hoek
Hi Ronald,
Hi Andrea,
Ronald Hoek
ronald.hoek@…8804…
email-groene-balk
ComponentAgro B.V.
Aston Martinlaan 70
info@…8804…
0186-622 220
Ian
Daniel Calliess
Postfach 63
5024 Salzburg
Ian Turton
Hi Andreas,
It could be added if you want, make a pull request.
Oh dear, yes, if you can live with 32bit addressing space only, load is indeed quite light :wink:
Hi Andrea,
I was thinking about where to add this instruction about creating the Windows installer.
Adding it to the ‘release’ section in the dev-manual is not a realy good place as this is not (no longer) a part of the release progress.
However, adding it to the USER manual is also a bit ‘strange’ – surely for non-tech users.
So I was thinking about a new section somewhere inside the DEV manual, to which can be pointed from the USER manual page of the Windows installer.
If you’re OK with this idea, l’ll try to make a suggestion/PULL how and where exactly…
Ronald Hoek
Verzonden: dinsdag 13 augustus 2019 14:02
On Tue, Aug 13, 2019 at 1:59 PM Ronald Hoek - ComponentAgro B.V. <ronald.hoek@…8804…> wrote:
Hi Andreas,
Hi Ronald,
a new section at the end of the developer guide, top level, would seem fine to me.
I still hope it’s just a temporary arrangement, and that eventually we’ll get back a Windows build
server, but there is no ETA, for the being a page there will be fine.
Hi Andrea,
I’ve made the modifications to the documentation (‘developer’ en ‘user’)
  • Added instruction to build the setup
  • Made a notification in the top-level (index) of the developer guide
  • Added a ‘warning’ in the ‘Windows Installer’ section of the ‘user’ guide
  • Create a PULL request: https://github.com/geoserver/geoserver/pull/3774
However, I don’t know how I can test whether the links are correctly working.
Ronald Hoek
ronald.hoek@…8804…
email-groene-balk
ComponentAgro B.V.
Aston Martinlaan 70
info@…8804…
0186-622 220
Verzonden: woensdag 28 augustus 2019 9:02
CC: Jody Garnett <jody.garnett@…84…>; GeoServer Mailing List List geoserver-users@lists.sourceforge.net
Hi Ronald,
On Mon, Aug 26, 2019 at 10:02 AM Ronald Hoek - ComponentAgro B.V. <ronald.hoek@…8804…> wrote:
Hi Andrea,
Ronald Hoek
CC: Jody Garnett <jody.garnett@…84…>; GeoServer Mailing List List <geoserver-users@lists.sourceforge.net>
Hi Andreas,
Also creates a Jira issue for this: https://osgeo-org.atlassian.net/browse/GEOS-9342
Met vriendelijke groet,
Ronald Hoek
Applicatiebeheerder
ronald.hoek@…8804…
email-groene-balk
ComponentAgro B.V.
Aston Martinlaan 70
info@…8804…
0186-622 220
De informatie in dit e-mailbericht, inclusief eventuele meegezonden bestanden, is uitsluitend bestemd voor de geadresseerde. Openbaarmaking aan derden, in welke vorm dan ook, is alleen toegestaan na toestemming van ComponentAgro. Ontvangt u dit bericht maar bent u niet de geadresseerde van deze e-mail, dan dient u het bericht definitief te verwijderen uit uw systeem en bestanden.
Van: Ronald Hoek - ComponentAgro B.V. <ronald.hoek@…8804…>
Verzonden: dinsdag 17 september 2019 11:35
Aan: andrea.aime@…1107…
Hi Andrea,
Ronald Hoek
ronald.hoek@…8804…
email-groene-balk
ComponentAgro B.V.
Aston Martinlaan 70
info@…8804…
0186-622 220
Hi Ronald,
Hi Andrea,
Ronald Hoek
Hi Andreas,
