Following directions at http://docs.geoserver.org/latest/en/developer/quickstart/index.html
I checked out and built the master branch successfully. But the maven build of 2.7.2 fails. I’m working on a Windows 7 client and have the latest git/maven installed.
This is my first use of git/maven. I could not see existing branches as the quickstart indicates. So maybe my reference to “2.7.2” is not valid. But git seems to accept that.
These are the steps I use to get/build at a windows cmd prompt:
C:\byers\git\geoserver2.7.2\src>mvn clean install
Maven kicks off the build including downloads and compiles and tests as it goes.
Watching the console I see this during the build, other tests continue afterwards:
Running org.geoserver.catalog.ResourcePoolTest
Tests run: 11, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 9.647 sec <<< F
AILURE!
testSEStyleWithRelativePathProtocol(org.geoserver.catalog.ResourcePoolTest) Tim
e elapsed: 5130 sec <<< ERROR!
java.lang.IllegalArgumentException: Contains invalid images\rockFillSymbol.png p
ath: /styles/
at org.geoserver.platform.resource.Paths.toPath(Paths.java:171)
at org.geoserver.platform.resource.Paths.path(Paths.java:114)
at org.geoserver.platform.resource.Paths.valid(Paths.java:194)
at org.geoserver.platform.resource.FileSystemResourceStore.get(FileSyste
mResourceStore.java:107)
at org.geoserver.platform.GeoServerResourceLoader.get(GeoServerResourceL
oader.java:173)
at org.geoserver.config.GeoServerDataDirectory.get(GeoServerDataDirector
y.java:113)
at org.geoserver.config.GeoServerDataDirectory.urlToResource(GeoServerDa
taDirectory.java:1413)
at org.geoserver.config.GeoServerDataDirectory$1.locateResource(GeoServe
rDataDirectory.java:1238)
at org.geotools.styling.SLDParser.parseExternalGraphic(SLDParser.java:18
at org.geotools.styling.SLDParser.parseGraphic(SLDParser.java:1673)
at org.geotools.styling.SLDParser.parseFill(SLDParser.java:2033)
at org.geotools.styling.SLDParser.parsePolygonSymbolizer(SLDParser.java:
at org.geotools.styling.SLDParser.parseRule(SLDParser.java:946)
at org.geotools.styling.SLDParser.parseFeatureTypeStyle(SLDParser.java:8
at org.geotools.styling.SLDParser.parseStyle(SLDParser.java:808)
at org.geotools.styling.SLDParser.parseNamedLayer(SLDParser.java:677)
at org.geotools.styling.SLDParser.parseDescriptor(SLDParser.java:469)
at org.geotools.styling.SLDParser.parseSLD(SLDParser.java:431)
at org.geoserver.catalog.SLDHandler.parse10(SLDHandler.java:116)
at org.geoserver.catalog.SLDHandler.parse(SLDHandler.java:108)
at org.geoserver.config.GeoServerDataDirectory.parsedStyle(GeoServerData
Directory.java:1257)
at org.geoserver.catalog.ResourcePool.getStyle(ResourcePool.java:1746)
at org.geoserver.catalog.impl.StyleInfoImpl.getStyle(StyleInfoImpl.java:
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.
java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces
sorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy
.java:146)
at com.sun.proxy.$Proxy13.getStyle(Unknown Source)
at org.geoserver.catalog.ResourcePoolTest.testSEStyleWithRelativePathPro
tocol(ResourcePoolTest.java:309)
java:57)
sorImpl.java:43)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(Framework
Method.java:47)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCal
lable.java:12)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMe
thod.java:44)
at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMet
hod.java:17)
at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.
java:26)
at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.ja
va:27)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRun
ner.java:70)
ner.java:50)
java:26)
va:27)
at org.apache.maven.surefire.junit4.JUnit4Provider.execute(JUnit4Provide
r.java:252)
at org.apache.maven.surefire.junit4.JUnit4Provider.executeTestSet(JUnit4
Provider.java:141)
at org.apache.maven.surefire.junit4.JUnit4Provider.invoke(JUnit4Provider
.java:112)
java:57)
sorImpl.java:43)
at org.apache.maven.surefire.util.ReflectionUtils.invokeMethodWithArray(
ReflectionUtils.java:189)
at org.apache.maven.surefire.booter.ProviderFactory$ProviderProxy.invoke
(ProviderFactory.java:165)
at org.apache.maven.surefire.booter.ProviderFactory.invokeProvider(Provi
derFactory.java:85)
at org.apache.maven.surefire.booter.ForkedBooter.runSuitesInProcess(Fork
edBooter.java:115)
at org.apache.maven.surefire.booter.ForkedBooter.main(ForkedBooter.java:
Then I get the output below:
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer … SUCCESS [ 1.634 s]
[INFO] Core Platform Module … SUCCESS [ 12.405 s]
[INFO] Open Web Service Module … SUCCESS [ 7.177 s]
[INFO] Main Module … FAILURE [02:40 min]
[INFO] GeoServer Security Modules … SKIPPED
[INFO] GeoServer JDBC Security Module … SKIPPED
[INFO] GeoServer LDAP Security Module … SKIPPED
Does anybody see where I’m going wrong?
Assuming I’m doing the right things, what would I do to fix this problem? Try importing just what I have at this point into eclipse and debug there to make the test succeed? Then continue the maven build?
Thank you - Walter
