After I managed to get a working SDE datastore, I tried to access my SDE
layers through GeoServer.
All worked fine until I tried to display my largest dataset (more than
6,000,000 entries, the whole roads of France).
The SDE connection failed because of the default value of the timeout
(apparently, 1000 ms is not enough to access the data with SDE).
But since this error, I am unable to have my SDE layers back in GeoServer :
I get the following message (even if I restart my Tomcat Container):
2008-02-15 09:18:13,259 ERROR [geoserver.global] - FeatureTypeInfo
TestSde:::EE.EE_CDT_CL_GEO ignored - as DataStore TestSde is
broken:java.lang.NoSuchFieldError: NONE
If I try to had a new SDE layer, I got the same message and the following
stack:
at
org.geotools.data.arcsde.ArcSDEAdapter.createAttributeTypes(ArcSDEAdapter.ja
va:418)
at
org.geotools.data.arcsde.ArcSDEAdapter.fetchSchema(ArcSDEAdapter.java:287)
at
org.geotools.data.arcsde.ArcSDEDataStore.getSchema(ArcSDEDataStore.java:202)
at
org.vfny.geoserver.action.data.DataFeatureTypesNewAction.execute(DataFeature
TypesNewAction.java:84)
at
org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
at
org.apache.struts.action.RequestProcessor.processActionPerform(RequestProces
sor.java:431)
at
org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
at
org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
at
org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(Application
FilterChain.java:269)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterCh
ain.java:188)
at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterE
ncodingFilter.java:108)
at
FilterChain.java:215)
at
ain.java:188)
at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterCh
ainProxy.java:264)
at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecur
ityInterceptor.java:107)
at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSec
urityInterceptor.java:72)
at
ainProxy.java:274)
at
org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslatio
nFilter.java:110)
at
ainProxy.java:274)
at
org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(Ano
nymousProcessingFilter.java:125)
at
ainProxy.java:274)
at
org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(Remember
MeProcessingFilter.java:142)
at
ainProxy.java:274)
at
org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(S
ecurityContextHolderAwareRequestFilter.java:81)
at
ainProxy.java:274)
at
org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFil
ter.java:217)
at
ainProxy.java:274)
at
org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106)
at
ainProxy.java:274)
at
org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpS
essionContextIntegrationFilter.java:229)
at
ainProxy.java:274)
at
org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at
org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at
at
ain.java:188)
at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.ja
va:213)
at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.ja
va:174)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117
at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java
:108)
at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:151)
at
org.apache.coyote.http11.Http11AprProcessor.process(Http11AprProcessor.java:
834)
at
org.apache.coyote.http11.Http11AprProtocol$Http11ConnectionHandler.process(H
ttp11AprProtocol.java:640)
at
org.apache.tomcat.util.net.AprEndpoint$Worker.run(AprEndpoint.java:1286)
at java.lang.Thread.run(Thread.java:619)
What should I do to get my SDE datastore back ? Create a new one ?
Restarting my computer ?
Moreover after the initial exception due to the SDE pool timeout, I got an
unexpected error for the JVM (I attached the dump file to the mail).
Apparently it is the imageio which is the problem : could it be linked to
the fact I deployed the native JAI ?
Alexandre
hs_err_pid1772.log (12.5 KB)
