[Geoserver-users] Unable to import time-series imagery with dates before 1 A.D.
Hi, I am trying to use the ImageMosaic plugin to import time series imagery with dates before 1 A.D. The process fails when I press Save on the import dialog. The error message I receive is:
Could not list layers for this store, an error occurred retrieving them: Failed to create reader from file:///Users/tag/Projects/EarthXLayers/LAYDB-28-geotiffs and hints null
The stack trace from the log file is below, as is a listing of the directory of files I’m trying to import. Here is my timeregex.properties and indexer.properties:
$cat timeregex.properties
regex=-?[0-9]{4}
$cat indexer.properties
TimeAttribute=ingestion
Schema=*the_geom:Polygon,location:String,ingestion:java.util.Date,elevation:Integer
PropertyCollectors=TimestampFileNameExtractorSPItimeregex
I am not using a database, just attempting to import from the file system.
The process works fine if I don’t include the tiff files with the minus sign in the file name. But the ISO 8601 spec seems to say that the minus sign is indeed how one would specify a date before 1 A.D.
Does anyone know how I can achieve what I’m trying to do, or whether it’s even possible? Any help would be much appreciated.
Here is a listing of the directory contents I’m trying to load. All the files are GeoTiffs of the same size. Again, removing the files with the minus sign in their name causes the process to work, but I need to include those files. This is model-generated data, of course, no satellites way back then.
-1000.tif
-2000.tif
-3000.tif
-4000.tif
-5000.tif
-6000.tif
0001.tif
0200.tif
0400.tif
0600.tif
0800.tif
1000.tif
1100.tif
1200.tif
1300.tif
1400.tif
1500.tif
1550.tif
1600.tif
1650.tif
1700.tif
1720.tif
1740.tif
1760.tif
1780.tif
1800.tif
1820.tif
1840.tif
1860.tif
1870.tif
1880.tif
1890.tif
1900.tif
1910.tif
1920.tif
1930.tif
1940.tif
1950.tif
1955.tif
1960.tif
1965.tif
1970.tif
1975.tif
1980.tif
1985.tif
1990.tif
1995.tif
2000.tif
indexer.properties
And here is the stack trace from the log:
18 Mar 16:17:55 INFO [geoserver.web] - Getting list of coverages for saved store file:///Users/tag/Projects/EarthXLayers/LAYDB-28-geotiffs
java.lang.RuntimeException: Could not list layers for this store, an error occurred retrieving them: Failed to create reader from file:///Users/tag/Projects/EarthXLayers/LAYDB-28-geotiffs and hints null
at org.geoserver.web.data.layer.NewLayerPageProvider.getItemsInternal(NewLayerPageProvider.java:150)
at org.geoserver.web.data.layer.NewLayerPageProvider.getItems(NewLayerPageProvider.java:57)
at org.geoserver.web.wicket.GeoServerDataProvider.fullSize(GeoServerDataProvider.java:243)
at org.geoserver.web.wicket.GeoServerTablePanel$PagerDelegate.updateMatched(GeoServerTablePanel.java:583)
at org.geoserver.web.wicket.GeoServerTablePanel$PagerDelegate.(GeoServerTablePanel.java:576)
at org.geoserver.web.wicket.GeoServerTablePanel.(GeoServerTablePanel.java:176)
at org.geoserver.web.wicket.GeoServerTablePanel.(GeoServerTablePanel.java:97)
at org.geoserver.web.data.layer.NewLayerPage$1.(NewLayerPage.java:105)
at org.geoserver.web.data.layer.NewLayerPage.(NewLayerPage.java:105)
at org.geoserver.web.data.store.CoverageStoreNewPage.onSuccessfulSave(CoverageStoreNewPage.java:78)
at org.geoserver.web.data.store.CoverageStoreNewPage.onSave(CoverageStoreNewPage.java:69)
at org.geoserver.web.data.store.AbstractCoverageStorePage$1.onSubmit(AbstractCoverageStorePage.java:116)
at org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1.onSubmit(AjaxSubmitLink.java:110)
at org.apache.wicket.ajax.form.AjaxFormSubmitBehavior$AjaxFormSubmitter.onSubmit(AjaxFormSubmitBehavior.java:215)
at org.apache.wicket.markup.html.form.Form.delegateSubmit(Form.java:1307)
at org.apache.wicket.markup.html.form.Form.process(Form.java:974)
at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:795)
at org.apache.wicket.ajax.form.AjaxFormSubmitBehavior.onEvent(AjaxFormSubmitBehavior.java:171)
at org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:155)
at org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:588)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.apache.wicket.RequestListenerInterface.internalInvoke(RequestListenerInterface.java:258)
at org.apache.wicket.RequestListenerInterface.invoke(RequestListenerInterface.java:241)
at org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.invokeListener(ListenerInterfaceRequestHandler.java:248)
at org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.respond(ListenerInterfaceRequestHandler.java:234)
at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:865)
at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:265)
at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:222)
at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:293)
at org.apache.wicket.protocol.http.WicketFilter.processRequestCycle(WicketFilter.java:261)
at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:203)
at org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:159)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:156)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:933)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:867)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:953)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:855)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:829)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:808)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1669)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1652)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:182)
at org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:116)
at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:146)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:343)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:260)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:88)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:106)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:585)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:215)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:110)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)
at org.eclipse.jetty.server.Server.handle(Server.java:499)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:310)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257)
at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:540)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.io.IOException: Failed to create reader from file:///Users/tag/Projects/EarthXLayers/LAYDB-28-geotiffs and hints null
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1443)
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1369)
at org.geoserver.catalog.impl.CoverageStoreInfoImpl.getGridCoverageReader(CoverageStoreInfoImpl.java:59)
at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:146)
at com.sun.proxy.$Proxy8.getGridCoverageReader(Unknown Source)
at org.geoserver.web.data.layer.NewLayerPageProvider.getItemsInternal(NewLayerPageProvider.java:88)
… 124 more
Dear Thomas,
probably beating a dead horse but it is worth answering.
From a cursory look the regex looks fine.
I suspect this might be an issue eith the datetime parser then.
I would suggest you to open a jira report and attach a sample tif ( or
instructions on how to get it/ generate it + the mosaic config you are
using), I can then ask one of the guys here to look at it.
Aside, a larger portion of the log when runnin in verbose mode might
help sotting the issue.
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
indexer.properties:
regex=-?[0-9]{4}
PropertyCollectors=TimestampFileNameExtractorSPI[timeregex](ingestion)
then.
-1000.tif
-2000.tif
-3000.tif
-4000.tif
-5000.tif
-6000.tif
0001.tif
0200.tif
0400.tif
0600.tif
0800.tif
1000.tif
1100.tif
1200.tif
1300.tif
1400.tif
1500.tif
1550.tif
1600.tif
1650.tif
1700.tif
1720.tif
1740.tif
1760.tif
1780.tif
1800.tif
1820.tif
1840.tif
1860.tif
1870.tif
1880.tif
1890.tif
1900.tif
1910.tif
1920.tif
1930.tif
1940.tif
1950.tif
1955.tif
1960.tif
1965.tif
1970.tif
1975.tif
1980.tif
1985.tif
1990.tif
1995.tif
2000.tif
indexer.properties
at
at
at
at
at
org.geoserver.web.wicket.GeoServerTablePanel$PagerDelegate.<init>(GeoServerTablePanel.java:576)
at
org.geoserver.web.wicket.GeoServerTablePanel.<init>(GeoServerTablePanel.java:176)
at
org.geoserver.web.wicket.GeoServerTablePanel.<init>(GeoServerTablePanel.java:97)
at org.geoserver.web.data.layer.NewLayerPage$1.<init>(NewLayerPage.java:105)
at org.geoserver.web.data.layer.NewLayerPage.<init>(NewLayerPage.java:105)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 124 more
Transform Data into Opportunity.
Accelerate data analysis in your applications with
Intel Data Analytics Acceleration Library.
Click to learn more.
http://pubads.g.doubleclick.net/gampad/clk?id=278785231&iu=/4140
Geoserver-users mailing list
