Dear Friends,
I am using geoserver 2.3.5 in my project when i try to load my published map in jpeg format i am getting a error like unable to load jpeg JDK ,what mite be the root clause of this issue
Hi Anas,
It may be worth updating to a newer version of GeoServer.
That said, if you can provide more information about the error (the exact error message for one thing, but also information about your configuration/environment), maybe someone will be able to assist.
Jonathan
This transmission is intended for the named addressee(s) only and may contain confidential, sensitive or personal information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Dear Friends,
Try right clicking on the “tile” and saving the contents as a text file. You will find the document is an xml “Service Exception” - which your application is trying to display as a JPEG.
Usually this is based on a configuration issue, or a bad request.
Dear Friends,
