[Geoserver-users] Unable to set startup-sql for Oracle NG datastore
Using geoserver 2.7.2…I need to execute some SQL on oracle connections obtained by geoserver. If I have the Session Startup SQL set then geoserver immediately shows an error that it can’t connect to the db.
Even the simplest SQL will reproduce the failure. My test SQL reads…
select sysdate from dual
If I save the settings like this in spite of the error then the same problem happens during geoserver startup and my data store is disabled.
Any thoughts on how I could work around this?
The exception I get when saving the data store this way is:
02 Oct 11:15:03 WARN [data.store] - Error obtaining datastore with the modified values
java.io.IOException: Unable to obtain Oracle Connection require for SDO Geometry access).Check connection pool implementation to unsure unwrap is available
at org.geotools.data.oracle.OracleNGDataStoreFactory.createDataStoreInternal(OracleNGDataStoreFactory.java:141)
at org.geotools.jdbc.JDBCDataStoreFactory.createDataStore(JDBCDataStoreFactory.java:269)
at org.geotools.jdbc.JDBCDataStoreFactory.createDataStore(JDBCDataStoreFactory.java:54)
at org.vfny.geoserver.util.DataStoreUtils.getDataAccess(DataStoreUtils.java:89)
at org.geoserver.catalog.ResourcePool.getDataStore(ResourcePool.java:585)
at org.geoserver.web.data.store.DataAccessEditPage.onSaveDataStore(DataAccessEditPage.java:129)
at org.geoserver.web.data.store.AbstractDataAccessPage$1.onSubmit(AbstractDataAccessPage.java:163)
at org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1.onSubmit(AjaxSubmitLink.java:68)
at org.apache.wicket.ajax.form.AjaxFormSubmitBehavior.onEvent(AjaxFormSubmitBehavior.java:143)
at org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:177)
at org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:300)
at org.apache.wicket.request.target.component.listener.BehaviorRequestTarget.processEvents(BehaviorRequestTarget.java:119)
at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:92)
at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1250)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436)
at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484)
at org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:160)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:159)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:182)
at org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:116)
at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:146)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:83)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:190)
at org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:291)
at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:769)
at org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:698)
at org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:891)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:690)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.sql.SQLException: Could not obtain native oracle connection for class org.geotools.jdbc.LifecycleConnection
at org.geotools.data.oracle.OracleDialect.unwrapConnection(OracleDialect.java:627)
at org.geotools.data.oracle.OracleNGDataStoreFactory.createDataStoreInternal(OracleNGDataStoreFactory.java:139)
… 108 more
Hi Walter,
I checked the code, in that case we have the native Oracle connection twice wrapped,
first in the lifecycle wrapper, and then in the connection pool one, but the code
only attempts one level of unwrapping.
One year ago we changed the unwrapping logic to avoid the logs being flooded with
messages, I guess that made the code regress (the old version was not exactly
trying to do multiple unwrap levels either, it must have worked by accident).
Can you open a bug report?
Also, if you can code in Java and want to speed up the resolution of this
issue, you should be looking at this class/method and make a pull request containing
a fix, and a test that avoids future regressions:
https://github.com/geotools/geotools/blob/master/modules/plugin/jdbc/jdbc-oracle/src/main/java/org/geotools/data/oracle/OracleDialect.java#L610
The test should probably be added in this class (and/or its superclass) by making it read some features with geometries:
https://github.com/geotools/geotools/blob/master/modules/plugin/jdbc/jdbc-oracle/src/test/java/org/geotools/data/oracle/OracleConnectionLifecycleOnlineTest.java
On Fri, Oct 2, 2015 at 1:32 PM, Walter Stovall <walter.stovall@anonymised.com> wrote:
… 108 more
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks for the response. I’d be delighted to open a bug report. I’m new to geoserver. Can you point me in the right direction for doing that?
I definitely want to get more involved with geoserver and do what I can to improve a very valuable product. I’m a good java developer but I have no history with maven (I’ve used ant). I’m not up to speed on getting and building the code but definitely want to go there! I’ve been distracted by trying to hit near term functional goals. So I won’t hit the ground running with this even though the coding sounds reasonably straightforward. Hopefully Monday I can return to the get/build thing and see what I can do.
Walter
Hi Walter,
On Fri, Oct 2, 2015 at 1:32 PM, Walter Stovall <walter.stovall@…7262…> wrote:
… 108 more
Ing. Andrea Aime
@geowolf
Technical Lead
On Fri, Oct 2, 2015 at 6:59 PM, Walter Stovall <walter.stovall@anonymised.com>
The bug tracker is here, I'm pointing at the geotools one since this issue
is fully contained inside
the GeoTools code:
https://osgeo-org.atlassian.net/projects/GEOT/summary
see what I can do.
Hi, for getting started you might want to look here:
http://docs.geotools.org/latest/developer/docs/index.html
I'm not too familiar with those docs, Jody and Ian, cc'ed, might give you
better getting started advice.
For making a pull request, see here:
https://github.com/geotools/geotools/blob/master/CONTRIBUTING.md
Ing. Andrea Aime
@geowolf
Technical Lead
Thank you – I created a JIRA account and bug:
https://osgeo-org.atlassian.net/browse/GEOT-5239
I wasn’t sure what to say with respect to affected-versions of GeoTools so I left that blank.
I’ll get getting my environment setup to contribute further.
Much thanks, Walter
On Fri, Oct 2, 2015 at 6:59 PM, Walter Stovall <walter.stovall@…7262…> wrote:
The bug tracker is here, I’m pointing at the geotools one since this issue is fully contained inside
the GeoTools code:
I’m not too familiar with those docs, Jody and Ian, cc’ed, might give you better getting started advice.
Ing. Andrea Aime
@geowolf
Technical Lead
