[Geoserver-users] Unable to start GeoServer - new install
I'm trying to install geoserver of FC4, I followed the detailed
instructions for unix installations but get the following output when
trying to start geoserver:
Can anyone help?
Thanks
Dan
GEOSERVER DATA DIR is /usr/local/geoserver/conf
15:47:25.559 EVENT Checking Resource aliases
15:47:26.206 EVENT Starting Jetty/4.2.21
15:47:26.219 EVENT Started ServletHttpContext[/]
15:47:26.222 EVENT Started SocketListener on 127.0.0.1:8081
15:47:26.222 EVENT Started org.mortbay.jetty.Server@anonymised.com
15:47:26.261 EVENT Starting Jetty/4.2.21
15:47:26.398 EVENT Started WebApplicationContext[/geoserver,GeoServer]
Nov 2, 2006 3:47:28 PM
org.vfny.geoserver.global.xml.XMLConfigWriter$WriterUtils initFile
SEVERE: Attempting to create file:/usr/local/geoserver/conf/services.xml
15:47:28.359 WARN!! action: null
java.lang.RuntimeException:
org.vfny.geoserver.global.ConfigurationException: ja va.io.IOException:
No such file or directory
        at
org.vfny.geoserver.global.ApplicationState.getXmlTimestamp(Applicatio
nState.java:525)
        at
org.vfny.geoserver.global.ApplicationState.init(ApplicationState.java
:96)
        at
org.apache.struts.action.ActionServlet.initModulePlugIns(ActionServle
t.java:1158)
        at
org.apache.struts.action.ActionServlet.init(ActionServlet.java:473)
        at javax.servlet.GenericServlet.init(GenericServlet.java:256)
        at
org.mortbay.jetty.servlet.ServletHolder.start(ServletHolder.java:220)
        at
org.mortbay.jetty.servlet.ServletHandler.initializeServlets(ServletHa
ndler.java:445)
        at
org.mortbay.jetty.servlet.WebApplicationHandler.initializeServlets(We
bApplicationHandler.java:150)
        at
org.mortbay.jetty.servlet.WebApplicationContext.start(WebApplicationC
ontext.java:458)
        at org.mortbay.http.HttpServer.start(HttpServer.java:663)
        at org.mortbay.jetty.Server.main(Server.java:429)
        at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.
java:39)
        at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces
sorImpl.java:25)
        at org.mortbay.start.Main.invokeMain(Main.java:152)
        at org.mortbay.start.Main.start(Main.java:482)
        at org.mortbay.start.Main.main(Main.java:90)
Caused by: org.vfny.geoserver.global.ConfigurationException:
java.io.IOException : No such file or directory
        at
org.vfny.geoserver.global.xml.XMLConfigWriter$WriterUtils.initFile(XM
LConfigWriter.java:1059)
        at
org.vfny.geoserver.global.xml.XMLConfigWriter$WriterUtils.initWriteFi
le(XMLConfigWriter.java:1097)
        at
nState.java:522)
        ... 17 more
Caused by: java.io.IOException: No such file or directory
        at java.io.UnixFileSystem.createFileExclusively(Native Method)
        at java.io.File.createNewFile(File.java:850)
        at
LConfigWriter.java:1053)
        ... 19 more
15:47:28.363 EVENT action: null: java.lang.RuntimeException:
org.vfny.geoserver .global.ConfigurationException: java.io.IOException:
15:47:28.364 WARN!! Failed to start: SocketListener@anonymised.com:8080
15:47:28.364 WARN!!
org.mortbay.util.MultiException[javax.servlet.UnavailableException,
java.net.Bin dException: Address already in use]
        at org.mortbay.http.HttpServer.start(HttpServer.java:640)
        at
java:39)
        at
sorImpl.java:25)
[0]=javax.servlet.UnavailableException
        at
t.java:1169)
        at
        at
        at
ndler.java:445)
        at
        at
ontext.java:458)
        at
java:39)
        at
sorImpl.java:25)
[1]=java.net.BindException: Address already in use
        at java.net.PlainSocketImpl.socketBind(Native Method)
        at java.net.PlainSocketImpl.bind(PlainSocketImpl.java:359)
        at java.net.ServerSocket.bind(ServerSocket.java:319)
        at java.net.ServerSocket.<init>(ServerSocket.java:185)
        at
org.mortbay.util.ThreadedServer.newServerSocket(ThreadedServer.java:3
09)
        at org.mortbay.util.ThreadedServer.open(ThreadedServer.java:380)
        at
org.mortbay.util.ThreadedServer.start(ThreadedServer.java:406)
        at
org.mortbay.http.SocketListener.start(SocketListener.java:154)
        at org.mortbay.http.HttpServer.start(HttpServer.java:671)
        at
java:39)
        at
sorImpl.java:25)
It looks like geoserver does not have permission to read or write to its configuration directory.
This would be your usr/local/geoserver/conf directory
You can tell geoserver to use a different location as its data directory. It comes with a default one located at [geoserver_home]/webapps/geoserver/conf
In your webapps/geoserver directory go to the WEB-INF directory and open up the web.xml file.
In it there is a commented-out xml element that is called <GEOSERVER_DATA_DIR>
You can put a url in that to point to the data directory of your choice. In that data directory you need two files: services.xml and config.xml, you also need some supporting directories. Pretty much everything that comes in the default webapps/geoserver/conf directory. So you can just have it point at the default geoserver data directory, make sure that geoserver/jetty have permissions to read/write from it, and everything should work.
Brent Owens
(The Open Planning Project)
Dan Lear wrote:
Can anyone help?
Thanks
Dan
        at
nState.java:525)
        at
:96)
        at
t.java:1158)
        at
        at
        at
ndler.java:445)
        at
        at
ontext.java:458)
        at
java:39)
        at
sorImpl.java:25)
        at
        at
        at
nState.java:522)
        ... 17 more
        at
        ... 19 more
15:47:28.364 WARN!!
        at
java:39)
        at
sorImpl.java:25)
        at
t.java:1169)
        at
        at
        at
ndler.java:445)
        at
        at
ontext.java:458)
        at
java:39)
        at
sorImpl.java:25)
        at
09)
        at
        at
        at
java:39)
        at
sorImpl.java:25)
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-users mailing list
