[Geoserver-users] Unable to start GeoServer - new install
Hi Brent & list,
Thanks for the reply, however I haven't got a
[geoserver_home]/webapps/geoserver/conf directory. Is it created the
first time geoserver starts up?
The contents of [geoserver_home] are:
bin documents lib README.txt server
data_dir GPL.txt license.txt RUNNING.txt
I didn't miss out any steps in the install, (I even re-installed this
morning). I am running Tomcat on port 8080, so modified the default
port in $GEOSERVER_HOME/documents/jetty.xml
Many thanks for your help
Dan
-----Original Message-----
From: geoserver-users-bounces@lists.sourceforge.net
[mailto:geoserver-users-bounces@lists.sourceforge.net] On Behalf Of
Brent Owens
Sent: 02 November 2006 17:25
To: Dan Lear
Subject: Re: [Geoserver-users] Unable to start GeoServer - new
install[Virus Scanned by MBA]
It looks like geoserver does not have permission to read or write to its
configuration directory.
This would be your usr/local/geoserver/conf directory
You can tell geoserver to use a different location as its data
directory. It comes with a default one located at
In your webapps/geoserver directory go to the WEB-INF directory and open
up the web.xml file.
In it there is a commented-out xml element that is called
<GEOSERVER_DATA_DIR> You can put a url in that to point to the data
directory of your choice.
In that data directory you need two files: services.xml and config.xml,
you also need some supporting directories. Pretty much everything that
comes in the default webapps/geoserver/conf directory. So you can just
have it point at the default geoserver data directory, make sure that
geoserver/jetty have permissions to read/write from it, and everything
should work.
Brent Owens
(The Open Planning Project)
Dan Lear wrote:
I'm trying to install geoserver of FC4, I followed the detailed
instructions for unix installations but get the following output when
trying to start geoserver:
Can anyone help?
Thanks
Dan
GEOSERVER DATA DIR is /usr/local/geoserver/conf
15:47:25.559 EVENT Checking Resource aliases
15:47:26.206 EVENT Starting Jetty/4.2.21
15:47:26.219 EVENT Started ServletHttpContext[/]
15:47:26.222 EVENT Started SocketListener on 127.0.0.1:8081
15:47:26.222 EVENT Started org.mortbay.jetty.Server@anonymised.com
15:47:26.261 EVENT Starting Jetty/4.2.21
15:47:26.398 EVENT Started
WebApplicationContext[/geoserver,GeoServer]
Nov 2, 2006 3:47:28 PM
org.vfny.geoserver.global.xml.XMLConfigWriter$WriterUtils initFile
SEVERE: Attempting to create
file:/usr/local/geoserver/conf/services.xml
15:47:28.359 WARN!! action: null
java.lang.RuntimeException:
org.vfny.geoserver.global.ConfigurationException: ja
va.io.IOException:
No such file or directory
        at
org.vfny.geoserver.global.ApplicationState.getXmlTimestamp(Applicatio
nState.java:525)
        at
org.vfny.geoserver.global.ApplicationState.init(ApplicationState.java
:96)
        at
org.apache.struts.action.ActionServlet.initModulePlugIns(ActionServle
t.java:1158)
        at
org.apache.struts.action.ActionServlet.init(ActionServlet.java:473)
        at javax.servlet.GenericServlet.init(GenericServlet.java:256)
        at
org.mortbay.jetty.servlet.ServletHolder.start(ServletHolder.java:220)
        at
org.mortbay.jetty.servlet.ServletHandler.initializeServlets(ServletHa
ndler.java:445)
        at
org.mortbay.jetty.servlet.WebApplicationHandler.initializeServlets(We
bApplicationHandler.java:150)
        at
org.mortbay.jetty.servlet.WebApplicationContext.start(WebApplicationC
ontext.java:458)
        at org.mortbay.http.HttpServer.start(HttpServer.java:663)
        at org.mortbay.jetty.Server.main(Server.java:429)
        at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.
java:39)
        at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces
sorImpl.java:25)
        at org.mortbay.start.Main.invokeMain(Main.java:152)
        at org.mortbay.start.Main.start(Main.java:482)
        at org.mortbay.start.Main.main(Main.java:90)
Caused by: org.vfny.geoserver.global.ConfigurationException:
java.io.IOException : No such file or directory
        at
org.vfny.geoserver.global.xml.XMLConfigWriter$WriterUtils.initFile(XM
LConfigWriter.java:1059)
        at
org.vfny.geoserver.global.xml.XMLConfigWriter$WriterUtils.initWriteFi
le(XMLConfigWriter.java:1097)
        at
nState.java:522)
        ... 17 more
Caused by: java.io.IOException: No such file or directory
        at java.io.UnixFileSystem.createFileExclusively(Native Method)
        at java.io.File.createNewFile(File.java:850)
        at
LConfigWriter.java:1053)
        ... 19 more
15:47:28.363 EVENT action: null: java.lang.RuntimeException:
org.vfny.geoserver .global.ConfigurationException:
15:47:28.364 WARN!! Failed to start: SocketListener@anonymised.com:8080
15:47:28.364 WARN!!
org.mortbay.util.MultiException[javax.servlet.UnavailableException,
java.net.Bin dException: Address already in use]
        at org.mortbay.http.HttpServer.start(HttpServer.java:640)
        at
java:39)
        at
sorImpl.java:25)
[0]=javax.servlet.UnavailableException
        at
t.java:1169)
        at
        at
        at
ndler.java:445)
        at
        at
ontext.java:458)
        at
java:39)
        at
sorImpl.java:25)
[1]=java.net.BindException: Address already in use
        at java.net.PlainSocketImpl.socketBind(Native Method)
        at java.net.PlainSocketImpl.bind(PlainSocketImpl.java:359)
        at java.net.ServerSocket.bind(ServerSocket.java:319)
        at java.net.ServerSocket.<init>(ServerSocket.java:185)
        at
org.mortbay.util.ThreadedServer.newServerSocket(ThreadedServer.java:3
09)
        at
org.mortbay.util.ThreadedServer.open(ThreadedServer.java:380)
        at
org.mortbay.util.ThreadedServer.start(ThreadedServer.java:406)
        at
org.mortbay.http.SocketListener.start(SocketListener.java:154)
        at org.mortbay.http.HttpServer.start(HttpServer.java:671)
        at
java:39)
        at
sorImpl.java:25)
--- Using Tomcat but need to do more? Need to support web services,
security?
Get stuff done quickly with pre-integrated technology to make your job
easier Download IBM WebSphere Application Server v.1.0.1 based on
Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=1216
42 _______________________________________________
Geoserver-users mailing list
security?
easier Download IBM WebSphere Application Server v.1.0.1 based on Apache
Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
oops, sorry Dan
It looks like you are using a 1.3 series of GeoServer where it is in a slightly different location. Look under /data_dir
That is the data directory for 1.3
You still configure it the same.
Brent Owens
Dan Lear wrote:
Hi Brent & list,
Dan
Brent Owens
To: Dan Lear
directory of your choice. In that data directory you need two files: services.xml and config.xml,
should work.
Brent Owens
Dan Lear wrote:
I'm trying to install geoserver of FC4, I followed the detailed instructions for unix installations but get the following output when trying to start geoserver:
Can anyone help?
Thanks
Dan
15:47:26.398 EVENT Started WebApplicationContext[/geoserver,GeoServer]
SEVERE: Attempting to create file:/usr/local/geoserver/conf/services.xml
va.io.IOException:
        at
nState.java:525)
        at
:96)
        at
t.java:1158)
        at
        at
        at
ndler.java:445)
        at
        at
ontext.java:458)
        at
java:39)
        at
sorImpl.java:25)
        at
        at
        at
nState.java:522)
        ... 17 more
        at
        ... 19 more
15:47:28.364 WARN!!
        at
java:39)
        at
sorImpl.java:25)
        at
t.java:1169)
        at
        at
        at
ndler.java:445)
        at
        at
ontext.java:458)
        at
java:39)
        at
sorImpl.java:25)
        at
09)
        at
        at
        at
        at
java:39)
        at
sorImpl.java:25)
--- Using Tomcat but need to do more? Need to support web services, security?
easier Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
security?
Geronimo
Get stuff done quickly with pre-integrated technology to make your job easier
