Dear List,
I have migrated a GS2.3.2 data directory from windows to Solaris Sparcv9 … under Weblogic12c. The data directory is valid since it has been running under windows fine but now when it is shifted to Solaris… Geowebcache seems to be causing the problem when all the required folders and files exist in data directory. Has anybody had this problem before ? Stack trace is as below
OS:Solaris Sparc
Container : Weblogic 12c
GS version : 2.3.2
JDK: Sun JDK 1.6.24
18 Jun 21:01:47 INFO [config.XMLConfiguration] - Will look for geowebcache.xml in ‘/u01/home/oracle/data_gs232/gwc’
18 Jun 21:01:47 WARN [support.DisposableBeanAdapter] - Invocation of destroy method failed on bean with name ‘geoServerLoader’: java.lang.NullPointerException
18 Jun 21:01:47 ERROR [context.ContextLoader] - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘gwcCatalogConfiguration’ defined in URL [zip:/u01/home/oracle/bea/user_projects/domains/cts_domain/servers/AdminServer/upload/geoserver.war/WEB-INF/lib/gwc-2.3.2.jar!/geowebcache-geoserver-context.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.geoserver.gwc.layer.CatalogConfiguration]: Constructor threw exception; nested exception is java.lang.NoSuchMethodError: com.google.common.util.concurrent.MoreExecutors.sameThreadExecutor()Lcom/google/common/util/concurrent/ListeningExecutorService;
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:288)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1035)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:939)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:485)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:585)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:913)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:464)
at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:385)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:284)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:111)
at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:22)
at weblogic.servlet.internal.EventsManager$FireContextListenerAction.run(EventsManager.java:582)
at weblogic.security.acl.internal.AuthenticatedSubject.doAs(AuthenticatedSubject.java:321)
at weblogic.security.service.SecurityManager.runAs(SecurityManager.java:120)
at weblogic.servlet.provider.WlsSubjectHandle.run(WlsSubjectHandle.java:57)
at weblogic.servlet.internal.EventsManager.executeContextListener(EventsManager.java:233)
at weblogic.servlet.internal.EventsManager.notifyContextCreatedEvent(EventsManager.java:190)
at weblogic.servlet.internal.EventsManager.notifyContextCreatedEvent(EventsManager.java:175)
at weblogic.servlet.internal.WebAppServletContext.preloadResources(WebAppServletContext.java:1730)
at weblogic.servlet.internal.WebAppServletContext.start(WebAppServletContext.java:2740)
at weblogic.servlet.internal.WebAppModule.startContexts(WebAppModule.java:1704)
at weblogic.servlet.internal.WebAppModule.start(WebAppModule.java:781)
at weblogic.application.internal.flow.ModuleStateDriver$3.next(ModuleStateDriver.java:213)
at weblogic.application.internal.flow.ModuleStateDriver$3.next(ModuleStateDriver.java:208)
at weblogic.application.utils.StateMachineDriver.nextState(StateMachineDriver.java:35)
at weblogic.application.internal.flow.ModuleStateDriver.start(ModuleStateDriver.java:70)
at weblogic.application.internal.flow.ScopedModuleDriver.start(ScopedModuleDriver.java:212)
at weblogic.application.internal.ExtensibleModuleWrapper.start(ExtensibleModuleWrapper.java:111)
at weblogic.application.internal.flow.ModuleListenerInvoker.start(ModuleListenerInvoker.java:124)
at weblogic.application.internal.flow.StartModulesFlow.activate(StartModulesFlow.java:24)
at weblogic.application.internal.BaseDeployment$2.next(BaseDeployment.java:729)
at weblogic.application.internal.BaseDeployment.activate(BaseDeployment.java:258)
at weblogic.application.internal.SingleModuleDeployment.activate(SingleModuleDeployment.java:48)
at weblogic.application.internal.DeploymentStateChecker.activate(DeploymentStateChecker.java:165)
at weblogic.deploy.internal.targetserver.AppContainerInvoker.activate(AppContainerInvoker.java:79)
at weblogic.deploy.internal.targetserver.operations.AbstractOperation.activate(AbstractOperation.java:582)
at weblogic.deploy.internal.targetserver.operations.ActivateOperation.activateDeployment(ActivateOperation.java:148)
at weblogic.deploy.internal.targetserver.operations.ActivateOperation.doCommit(ActivateOperation.java:114)
at weblogic.deploy.internal.targetserver.operations.StartOperation.doCommit(StartOperation.java:149)
at weblogic.deploy.internal.targetserver.operations.AbstractOperation.commit(AbstractOperation.java:335)
at weblogic.deploy.internal.targetserver.DeploymentManager.handleDeploymentCommit(DeploymentManager.java:844)
at weblogic.deploy.internal.targetserver.DeploymentManager.activateDeploymentList(DeploymentManager.java:1253)
at weblogic.deploy.internal.targetserver.DeploymentManager.handleCommit(DeploymentManager.java:440)
at weblogic.deploy.internal.targetserver.DeploymentServiceDispatcher.commit(DeploymentServiceDispatcher.java:163)
at weblogic.deploy.service.internal.targetserver.DeploymentReceiverCallbackDeliverer.doCommitCallback(DeploymentReceiverCallbackDeliverer.java:195)
at weblogic.deploy.service.internal.targetserver.DeploymentReceiverCallbackDeliverer.access$100(DeploymentReceiverCallbackDeliverer.java:13)
at weblogic.deploy.service.internal.targetserver.DeploymentReceiverCallbackDeliverer$2.run(DeploymentReceiverCallbackDeliverer.java:68)
at weblogic.work.SelfTuningWorkManagerImpl$WorkAdapterImpl.run(SelfTuningWorkManagerImpl.java:545)
at weblogic.work.ExecuteThread.execute(ExecuteThread.java:256)
at weblogic.work.ExecuteThread.run(ExecuteThread.java:221)
Caused by: org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.geoserver.gwc.layer.CatalogConfiguration]: Constructor threw exception; nested exception is java.lang.NoSuchMethodError: com.google.common.util.concurrent.MoreExecutors.sameThreadExecutor()Lcom/google/common/util/concurrent/ListeningExecutorService;
at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:162)
at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:110)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:280)
… 59 more
Caused by: java.lang.NoSuchMethodError: com.google.common.util.concurrent.MoreExecutors.sameThreadExecutor()Lcom/google/common/util/concurrent/ListeningExecutorService;
at com.google.common.cache.LocalCache.(LocalCache.java:155)
at com.google.common.cache.LocalCache$LocalManualCache.(LocalCache.java:4750)
at com.google.common.cache.LocalCache$LocalLoadingCache.(LocalCache.java:4858)
at com.google.common.cache.CacheBuilder.build(CacheBuilder.java:739)
at org.geoserver.gwc.layer.CatalogConfiguration.(CatalogConfiguration.java:148)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:147)
… 61 more
<Jun 18, 2013 9:01:47 PM PKT> <User defined listener org.geoserver.platform.GeoServerContextLoaderListener failed: org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘gwcCatalogConfiguration’ defined in URL [zip:/u01/home/oracle/bea/user_projects/domains/cts_domain/servers/AdminServer/upload/geoserver.war/WEB-INF/lib/gwc-2.3.2.jar!/geowebcache-geoserver-context.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.geoserver.gwc.layer.CatalogConfiguration]: Constructor threw exception; nested exception is java.lang.NoSuchMethodError: com.google.common.util.concurrent.MoreExecutors.sameThreadExecutor()Lcom/google/common/util/concurrent/ListeningExecutorService;.
Truncated. see log file for complete stacktrace
Caused By: org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.geoserver.gwc.layer.CatalogConfiguration]: Constructor threw exception; nested exception is java.lang.NoSuchMethodError: com.google.common.util.concurrent.MoreExecutors.sameThreadExecutor()Lcom/google/common/util/concurrent/ListeningExecutorService;
Caused By: java.lang.NoSuchMethodError: com.google.common.util.concurrent.MoreExecutors.sameThreadExecutor()Lcom/google/common/util/concurrent/ListeningExecutorService;
<Jun 18, 2013 9:01:47 PM PKT> <Could not load user defined filter in web.xml: org.springframework.web.filter.DelegatingFilterProxy.
regards,
I.R
Hi Imran,
Probably worth reporting as a bug - I think GeoServer is supposed to be platform agnostic.
Also, you’re running a very old version of Java there. Might be worth updating to the last Java 6 - it’s unlikely to fix this issue, but security updates abound.
Jonathan
On 18 June 2013 19:09, Imran Rajjad <rajjad@anonymised.com> wrote:
Dear List,
OS:Solaris Sparc
GS version : 2.3.2
JDK: Sun JDK 1.6.24
… 59 more
… 61 more
regards,
I.R
This SF.net email is sponsored by Windows:
Build for Windows Store.
http://p.sf.net/sfu/windows-dev2dev
Geoserver-users mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
On Fri, Jun 21, 2013 at 11:50 AM, Jonathan Moules <
jonathanmoules@anonymised.com> wrote:
Hi Imran,
platform agnostic.
Hum... I'd suggest not to open a bug report on this one.
The stack trace clearly points to a classpath problem, this kind of problem
is always container
specific, probably someone deployed an old version of Guava as part of the
web container
global libs.
Nothing to fix in GeoServer, that is.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
if its classpath problem then how come it starts nicely when you point it to a fresh default data directory? this issue was not in the previous 2.2.x series.
regards,
Imran
On Fri, Jun 21, 2013 at 3:05 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Fri, Jun 21, 2013 at 11:50 AM, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
I.R
Hi Imran,
Hum… I’d suggest not to open a bug report on this one.
The stack trace clearly points to a classpath problem, this kind of problem is always container
specific, probably someone deployed an old version of Guava as part of the web container
global libs.
Ing. Andrea Aime
@geowolf
Technical Lead
Ok it seems that I have figured out…it was actually an old version of a class referenced in gauva.jar packed inside geoserver. The conflicting jars are com.google.common_1.0.0.0_0-6.jar and gauva.jar ... one way is to replace the weblogic
s module jar with gauva.jar and rename it to com.google… or you can unpack the war file and put weblogic.xml in web-inf folder forcing weblogic to prefer web applications libraries over weblogics libraries.. your weblogic.xml should look like as below
<?xml version="1.0" encoding="UTF-8"?><wls:weblogic-web-app xmlns:wls="[http://xmlns.oracle.com/weblogic/weblogic-web-app](http://xmlns.oracle.com/weblogic/weblogic-web-app)" xmlns:xsi="[http://www.w3.org/2001/XMLSchema-instance](http://www.w3.org/2001/XMLSchema-instance)" xsi:schemaLocation="[http://java.sun.com/xml/ns/javaee](http://java.sun.com/xml/ns/javaee) [http://java.sun.com/xml/ns/javaee/web-app_2_5.xsd](http://java.sun.com/xml/ns/javaee/web-app_2_5.xsd) [http://xmlns.oracle.com/weblogic/weblogic-web-app](http://xmlns.oracle.com/weblogic/weblogic-web-app) [http://xmlns.oracle.com/weblogic/weblogic-web-app/1.1/weblogic-web-app.xsd](http://xmlns.oracle.com/weblogic/weblogic-web-app/1.1/weblogic-web-app.xsd)">
<wls:container-descriptor>
<wls:prefer-application-packages>
<wls:package-name>com.google.common.*</wls:package-name>
</wls:prefer-application-packages>
</wls:container-descriptor>
</wls:weblogic-web-app>
regards,
Imran
regards,
Imran
I.R
I.R
Hi Imran,
global libs.
Ing. Andrea Aime
@geowolf
Technical Lead
