Samuel Doyle wrote:
Upgrading to 1.4.0 did the trick, I'm not sure how I ended up getting the -M1 release.
Now that this is working do you know of anyone who is using kaMap with GeoServer? We are using kaMap with MapServer at the moment but would like to eliminate the use of both Apache and PHP if possible.
TileCache - http://labs.metacarta.com/wms-c/ plus OpenLayers does just about everything that kaMap does and a bit more. You can use kaMap plus Squid with GeoServer, but I'd just use TileCache. I've been meaning to write up a tutorial on TileCache plus GeoServer. I can try to do that soon, or just let me know if you need help.
It's written in Python, and the default is to use it with apache, but you can use something like http://www.lighttpd.net/ with a patch that should be in the next release.
If you want a pure Java caching solution, you can use OSCache, see http://docs.codehaus.org/display/GEOSDOC/Caching, plus OpenLayers to get caching. We tested a bit with it, but we liked TileCache a lot more. We may try to port it to pure Java somewhere down the line.
best regards,
Chris
Thanks, S.D.
*/Chris Holmes <cholmes@anonymised.com>/* wrote:
Could you turn on Config -> Server -> Verbose Exceptions? That will
give you a bigger response that we'll have an easier time with.
And please upgrade to 1.4.0 if you haven't already. 1.4.0-M1 is
'alpha', like not even quite beta, just our first milestone towards
1.4.0. There have been almost 10 releases since then.
best regards,
Chris
Samuel Doyle wrote:
> After installing JAI I end up with this under Tomcat 6.0.:
> ServiceExceptionReport SYSTEM
"http://midtown:8080/geoserver/schemas//wms/1.1.1/WMS_exception_1_1_1.dtd">
> null
> */Samuel Doyle /* wrote:
> I'm downloaded and installed from geoserver-1.4.0-M1-war.zip.
> S.D.
> */Chris Holmes /* wrote:
> Are you on 1.4.0 or 1.5.x?
> It's a problem with JAI. If you install JAI (java advanced
> imaging) it
> should work. We ship the jars with 1.4.0, so it's weird that
> glassfish
> doesn't pick those up. If you're on 1.5.0-beta1 you need JAI. In
> the
> future we'll have it so it will at least work without those.
> Chris
> Samuel Doyle wrote:
> > Yeah when I used the GetMap example it responded with this:
> > javax/media/jai/util/Range
> > So it looks like image drawing doesn't work. I can try under
> Tomcat but
> > was hoping it would work under GlassFish, I'm not sure what the
> > difference would be though.
> > S.D.
> > On Wed, January 3, 2007 5:12 pm, Samuel Doyle wrote:
> > > Hi,
> > > Thanks for the quick response.
> > > I have deployed GeoServer as a war under GlassFish running
> under
> > Linux.
> > Oh nice. I don't know for sure of anyone for sure with
> glassfish, would
> > definitely like to get it working so we can add it to the list of
> > servers
> > we know work.
> > > There are no errors in the deployment or indications in the
> logs.
> > I am
> > > able to see an xml generated output using the:
http://localhost:8080/geoserver/wfs?request=getfeature&service=wfs&versio
> > > n=1.0.0&typename=tutorial as specified in the example. What do
> > you mean by
> > > "Will the GetMap ones generate images?"
> > Sorry, was a bit too terse. That's good to know the WFS
> works. What I'm
> > asking is, if you go to Demo -> Sample Requests there's a few
> requests
> > that do GetMap requests. I think one is called GetMap.url,
> and it does a
> > wms getMap request (which is what mapbuilder also does). If you
> > select it
> > and use it, does it return a map of the US? Or errors?
> > Another thing to try is to use udig -
> http://udig.refractions.net - and
> > see if that will display the WMS. Basically we want to figure
> out if
> > it's
> > a problem with GeoServer, or just with MapBuilder.
> > best regards,
> > Chris
> > > Thanks, S.D.
> > > Chris Holmes wrote: What version of GeoServer are
> > > you using? What operating system? Are you use a binary
> installed
> > > version, or the war? Do you see any errors in the log? We've
> > experienced
> > > it before, but it's hard to diagnose the problem without more
> > information.
> > > Also do the 'sample requests' work? Will the GetMap ones
> generate
> > > images? If not what errors do they give?
> > > best regards,
> > > Chris
> > > On Wed, January 3, 2007 4:45 pm, Samuel Doyle wrote:
> > >> When following the demo for GeoServer to use the
> MapBuilder based
> > >> preview:
> > >> http://localhost:8080/geoserver/mapPreview.do
> > >> All the layer images come up as broken links. The application
> > launches
> > >> but there is no image not just for my tutorial example but
> all the
> > >> others. Has anyone else encountered this?
> > >> Thanks, S.D.
> > >> Take Surveys. Earn Cash. Influence the Future of IT
> > >> Join SourceForge.net's Techsay panel and you'll get the chance
> > to share
> > >> your opinions on IT & business topics through brief surveys -
> > and earn
> > >> cash
http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVD
> > >> EV
> > >> _______________________________________________
> > >> Geoserver-users mailing list
> > >> Geoserver-users@lists.sourceforge.net
> > >> https://lists.sourceforge.net/lists/listinfo/geoserver-users
> > > Chris Holmes
> > > The Open Planning Project
> > > http://topp.openplans.org
> > Chris Holmes
> > !DSPAM:1003,459c374a95861775926497!
> Chris Holmes
> begin:vcard
> fn:Chris Holmes
> n:Holmes;Chris
> org:The Open Planning Project
> adr:;;377 Broadway, 11th Floor;New York;NY;10013;USA
> email;internet:cholmes@anonymised.com
> title:VP, Strategic Development
> x-mozilla-html:FALSE
> url:http://topp.openplans.org
> version:2.1
> end:vcard
> Join SourceForge.net's Techsay panel and you'll get the chance to
> share your
> opinions on IT & business topics through brief surveys - and earn
cash
http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV_______________________________________________
> !DSPAM:1003,459c3c6299014750375898!
-- Chris Holmes
begin:vcard
fn:Chris Holmes
n:Holmes;Chris
version:2.1
end:vcard
!DSPAM:1003,459c4d80108761336712104!
opinions on IT & business topics through brief surveys - and earn cash
Chris Holmes
