[Geoserver-users] Unable to view maps in MapBuilder deployed with GeoServer (Demo)
When following the demo for GeoServer to use the MapBuilder based preview:
http://localhost:8080/geoserver/mapPreview.do
All the layer images come up as broken links. The application launches but there is no image not just for my tutorial example but all the others. Has anyone else encountered this?
Thanks, S.D.
What version of GeoServer are you using? What operating system? Are you
use a binary installed version, or the war? Do you see any errors in the
log? We've experienced it before, but it's hard to diagnose the problem
without more information.
Also do the 'sample requests' work? Will the GetMap ones generate images?
If not what errors do they give?
best regards,
Chris
preview:
Thanks, S.D.
!DSPAM:1003,459c24ec77652207481331!
Join SourceForge.net's Techsay panel and you'll get the chance to share
your opinions on IT & business topics through brief surveys - and earn
cash
Geoserver-users mailing list
Chris Holmes
The Open Planning Project
http://topp.openplans.org
Thanks for the quick response.
I have deployed GeoServer as a war under GlassFish running under Linux.
There are no errors in the deployment or indications in the logs. I am able to see an xml generated output using the:
http://localhost:8080/geoserver/wfs?request=getfeature&service=wfs&version=1.0.0&typename=tutorial
as specified in the example. What do you mean by “Will the GetMap ones generate images?”
Thanks, S.D.
log? We’ve experienced it before, but it’s hard to diagnose the problem
Also do the ‘sample requests’ work? Will the GetMap ones generate images?
best regards,
Chris
preview:
Thanks, S.D.
Join SourceForge.net’s Techsay panel and you’ll get the chance to share
cash
Chris Holmes
