[Geoserver-users] Understanding stack traces
Hi folks,
I get this error message frequently but everything seems to work. I assume it is related to an old setting I no longer need but it does clog up the log files.
Is there any clue in this stack trace that would let me know which bit of the data directory I should be looking in to find the incorrect login details?
WARN [geoserver.security] - JDBC connect error
org.springframework.security.authentication.AuthenticationServiceException: JDBC connect error
at org.geoserver.security.jdbc.JDBCConnectAuthProvider.authenticate(JDBCConnectAuthProvider.java:95)
at org.geoserver.security.GeoServerAuthenticationProvider.authenticate(GeoServerAuthenticationProvider.java:58)
at org.springframework.security.authentication.ProviderManager.authenticate(ProviderManager.java:156)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:168)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:239)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:48)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:219)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:142)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:610)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:537)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1085)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:658)
at org.apache.coyote.http11.Http11AprProtocol$Http11ConnectionHandler.process(Http11AprProtocol.java:277)
at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.doRun(AprEndpoint.java:2407)
at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:2396)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.sql.SQLException: ORA-01017: invalid username/password; logon denied
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:447)
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:389)
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:382)
at oracle.jdbc.driver.T4CTTIfun.processError(T4CTTIfun.java:675)
at oracle.jdbc.driver.T4CTTIoauthenticate.processError(T4CTTIoauthenticate.java:448)
at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:513)
at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:227)
at oracle.jdbc.driver.T4CTTIoauthenticate.doOAUTH(T4CTTIoauthenticate.java:383)
at oracle.jdbc.driver.T4CTTIoauthenticate.doOAUTH(T4CTTIoauthenticate.java:776)
at oracle.jdbc.driver.T4CConnection.logon(T4CConnection.java:432)
at oracle.jdbc.driver.PhysicalConnection.(PhysicalConnection.java:553)
at oracle.jdbc.driver.T4CConnection.(T4CConnection.java:254)
at oracle.jdbc.driver.T4CDriverExtension.getConnection(T4CDriverExtension.java:32)
at oracle.jdbc.driver.OracleDriver.connect(OracleDriver.java:528)
at java.sql.DriverManager.getConnection(DriverManager.java:571)
at java.sql.DriverManager.getConnection(DriverManager.java:215)
at org.geoserver.security.jdbc.JDBCConnectAuthProvider.authenticate(JDBCConnectAuthProvider.java:90)
… 51 more
Best Regards,
Paul Wittle
GIS Developer
Ext: 710 8473
Tel: 01305 228473
Hi
Go to “Authentication”, I think you will se a JDBC Authentication Provider at the bottom of the page. Try to delete it.
Chrilstian
On Tue, Sep 13, 2016 at 9:47 AM, Paul Wittle <P.Wittle@anonymised.com> wrote:
Hi folks,
… 51 more
Best Regards,
Paul Wittle
GIS Developer
Ext: 710 8473
Tel: 01305 228473
“This e-mail is intended for the named addressee(s) only and may contain information about individuals or other sensitive information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this email in error, kindly disregard the content of the message and notify the sender immediately. Please be aware that all email may be subject to recording and/or monitoring in accordance with relevant legislation.”
Geoserver-users mailing list
Geoserver-users@anonymised.com.382…sourceforge.net
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
Hi Paul,
I’m not too familiar with that part of the code, but my guess is that you’re authenticating against a dbms
(as in, checking if the username/pw combination allows a login into the db) and the logging level for
the login failure is just set too high (someone mistyping the password is normal business, it’s not a warning
worthy event, although someone making 100 errors in a row would indeed be noteworthy…)
On Tue, Sep 13, 2016 at 9:47 AM, Paul Wittle <P.Wittle@anonymised.com193…> wrote:
Hi folks,
… 51 more
Best Regards,
Paul Wittle
GIS Developer
Ext: 710 8473
Tel: 01305 228473
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
I do have one but it works and is needed isn’t it? My appsJDBC is linked to a user group service called application_users which works and provides a load of users to the application. These appear fine and when you test the connection on the application users it says it is fine.
There is an option to test the connection with a username and password but it doesn’t store those credentials.
I currently run a provider chain that goes appsJDBC (which runs Authkey) then default. My understanding is that if I delete the authentication provider then Authkey would stop working.
It seems odd to have a username and password error for a section of the GeoServer which, as far as I can see, has nowhere to actually store any username and password?
Paul
Hi
Chrilstian
On Tue, Sep 13, 2016 at 9:47 AM, Paul Wittle <P.Wittle@…7193…> wrote:
Hi folks,
… 51 more
Best Regards,
Paul Wittle
GIS Developer
Ext: 710 8473
Tel: 01305 228473
Hi Paul
The Jdbc authentication provider has nothing to do with a Jdbc user group service.
The Jdbc authentication provider wants an existing Oracle user and not a user contained in your user/group service.
Try to remove the provider and use the default provider.
Christian
On Tue, Sep 13, 2016 at 10:34 AM, Paul Wittle <P.Wittle@anonymised.com> wrote:
Paul
From: Christian Mueller [mailto:christian.mueller@anonymised.comsolutions.at]
Sent: 13 September 2016 09:03
To: Paul Wittle
Cc: geoserver-users@anonymised.comsourceforge.net
Subject: Re: [Geoserver-users] Understanding stack traces
Hi
Chrilstian
Hi folks,
… 51 more
Best Regards,
Paul Wittle
GIS Developer
Ext: 710 8473
Tel: 01305 228473
Geoserver-users@anonymised.comsourceforge.net
