[Geoserver-users] unfilled polygons
Hi
we are using GeoServer’s pdf output option to generate high quality pdf-maps (we just put some title, north arrow and frame around it with a small servlet). Filling polygons with a raster image gives me some headache: Sometimes some polygons are not filled with the raster image [1]. This only happens when setting transparent=true. They are filled when using transparent=false [2]. The same polygon is filled by changing the bounding box [3]. Please note the color of the stripes of the left polygon in [2] (should be the same as in the right polygon).
It occurs with shapefiles and postgis data and with GeoServer 1.5.4, 1.6.4b and the latest trunk version.
I was looking into the PDFMapProducer class but wasn’t able to see something special. Probably it’s an iText related problem? Any help etc. is appreciated!
[1] http://www.john-longo.org/geo/true.pdf
[2] http://www.john-longo.org/geo/false.pdf
[3] http://www.john-longo.org/geo/true2.pdf
regards
Stefan
Mit freundlichem Gruss
Stefan Ziegler
Leiter Aufsicht
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
Rötistrasse 4
4501 Solothurn
Telefon 032 627 75 96
Telefax 032 627 75 98
stefan.ziegler@anonymised.com
http://www.so.ch
Ziegler Stefan ha scritto:
Hi
we are using GeoServer's pdf output option to generate high quality pdf-maps (we just put some title, north arrow and frame around it with a small servlet). Filling polygons with a raster image gives me some headache: Sometimes some polygons are not filled with the raster image [1]. This only happens when setting transparent=true. They are filled when using transparent=false [2]. The same polygon is filled by changing the bounding box [3]. Please note the color of the stripes of the left polygon in [2] (should be the same as in the right polygon).
I was looking into the PDFMapProducer class but wasn't able to see something special. Probably it's an iText related problem? Any help etc. is appreciated!
Indeed it seems an issue with iText, as far as I remember we just
render PDF as we render any other image format, and iText does the
work of translating our java2d calls into a pdf output.
Maybe try your chance by upgrading iText? I believe GeoServer is
using a pretty old version, 2.0.6, whilst the latest is 2.1.3
