I was incorrect in calling them layers. Each of those is actually a geometry…each is one record in a feature layer. I guess what I really need is just an example of how to write the filter for the union function…for wms or wfs…I just can’t get my head around the syntax of some of these filters.
How would I write the filter for “(select the_geom where name=name1) union (select the_geom where name=name2)”? …it sounds so simple but I just cant figure it out!
Thanks Again,
Steve
On Mon, 12 Mar 2007 15:24:51 -0400 Chris Holmes wrote:
I don't believe that function is built for unioning layers. It's just for doing a union of a geometry, I believe, from the JTS library. I could be wrong, but I just don't think you can call two layers at once for it. I think that WMS is limited in this front, to do it in the OGC way I think would be to get a Web Processing Service to do the union, and then WMS of the results. Chris Stephen Crawford wrote: > All, > > I'm trying to see the union of two layers via wms. When I try SLD_BODY= > > <StyledLayerDescriptor> > <NamedLayer> > <Name>cei:breeding</Name> > <UserStyle> > <Name>myUnion</Name> > <FeatureTypeStyle> > <Rule> > <Filter> > <Function > name="union"> > > <PropertyIsEqualTo> > > <PropertyName>sci_name</PropertyName> > > <Literal>Accipiter cooperii</Literal> > > </PropertyIsEqualTo> > > <PropertyIsEqualTo> > > <PropertyName>sci_name</PropertyName> > > <Literal>Buteo jamaicensis</Literal> > > </PropertyIsEqualTo> > </Function> > </Filter> > <PolygonSymbolizer> > <Fill> > > <CssParameter name="fill">#fe9929</CssParameter> > > <CssParameter name="fill-opacity">1</CssParameter> > </Fill> > </PolygonSymbolizer> > </Rule> > </FeatureTypeStyle> > </UserStyle> > </NamedLayer> > </StyledLayerDescriptor> > > I get the union of ALL the features in the layer; I just want to get the > union the polys where sci_name=species1 and sci_name=species2. Any ideas on > how I should write this query? > > Thanks, > Steve > > Stephen Crawford > Center for Environmental Informatics > GeoVISTA Center > The Pennsylvania State University > 814.865.9905 > src176@anonymised.com > > > ------------------------------------------------------------------------- > Take Surveys. Earn Cash. Influence the Future of IT > Join SourceForge.net's Techsay panel and you'll get the chance to share your > opinions on IT & business topics through brief surveys-and earn cash > [http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV](http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV) > _______________________________________________ > Geoserver-users mailing list > Geoserver-users@lists.sourceforge.net > [https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users) > > !DSPAM:1003,45f4526a7651804284693! > -- Chris Holmes The Open Planning Project [http://topp.openplans.org](http://topp.openplans.org) --- cholmes.vcf
Stephen Crawford
GeoVISTA Center
