[Geoserver-users] unpredictable ArcSDE behaviour
Hi list,
sometimes one of our layers will load correctly, but then the next time it
won't. The log file gives the following info, mainly:
DATABASE LEVEL ERROR OCCURRED.
Does this ring a bell for anynone?
Stack trace below:
2008-02-20 12:52:03,358 DEBUG [org.geotools.arcsde.data.ArcSDEDataStore] -
getBounds
2008-02-20 12:52:03,358 DEBUG [org.geotools.arcsde.data.ArcSDEQuery] -
Creating new ArcSDEQuery
[org.geotools.arcsde.pool.ArcSDEConnectionPool] - Connection validated,
returned user DID
2008-02-20 12:52:03,359 DEBUG
returned user DID
2008-02-20 12:52:03,360 DEBUG
returned user DID
2008-02-20 12:52:03,361 DEBUG
returned user DID
returned user DID
2008-02-20 12:52:03,362 DEBUG
returned user DID
2008-02-20 12:52:03,363 DEBUG
returned user DID
2008-02-20 12:52:03,363 DEBUG [org.geotools.arcsde.data.ArcSDEQuery] - SQL
portion of SDE Query: 'Filter.INCLUDE'
Spatial-Filter portion of SDE Query: '[ SHAPE bbox POLYGON
((-207840.93382456363 310839.636846003, -207840.93382456363
589160.363153997, 507840.93382456363 589160.363153997, 507840.93382456363
310839.636846003, -207840.93382456363 310839.636846003)) ]'
Unsupported (and therefore ignored) portion of SDE Query: 'Filter.INCLUDE'
Building a new SeQuery to consult it's resulting envelope
2008-02-20 12:52:03,370 ERROR [org.geotools.arcsde.data.ArcSDEQuery] -
filter: [ SHAPE bbox POLYGON ((-207840.93382456363 310839.636846003,
-207840.93382456363 589160.363153997, 507840.93382456363 589160.363153997,
507840.93382456363 310839.636846003, -207840.93382456363 310839.636846003))
SQL: null
com.esri.sde.sdk.client.SeException:
        at com.esri.sde.sdk.client.j.a(Unknown Source)
        at com.esri.sde.sdk.client.SeQuery.calculateLayerExtent(Unknown
Source)
        at
org.geotools.arcsde.data.ArcSDEQuery.calculateQueryExtent(ArcSDEQuery.java:682)
        at
org.geotools.arcsde.data.ArcSDEQuery.calculateQueryExtent(ArcSDEQuery.java:592)
        at
org.geotools.arcsde.data.ArcSDEDataStore.getBounds(ArcSDEDataStore.java:1032)
        at
org.geotools.data.AbstractFeatureSource.getBounds(AbstractFeatureSource.java:228)
        at
org.geotools.data.DefaultFeatureResults.getBounds(DefaultFeatureResults.java:249)
        at
org.geotools.data.crs.ForceCoordinateSystemFeatureResults.getBounds(ForceCoordinateSystemFeatureResults.java:118)
        at
org.geotools.gml.producer.FeatureTransformer$FeatureTranslator.encode(FeatureTransformer.java:416)
        at
org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:702)
        at
org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:463)
        at
org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:295)
        at
org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:128)
        at
org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:107)
        at
org.geoserver.wfs.xml.GML2OutputFormat.encode(GML2OutputFormat.java:241)
        at
org.geoserver.wfs.xml.GML2OutputFormat.write(GML2OutputFormat.java:260)
        at
org.geoserver.wfs.WFSGetFeatureOutputFormat.write(WFSGetFeatureOutputFormat.java:137)
        at org.geoserver.ows.Dispatcher.response(Dispatcher.java:615)
        at
org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:192)
        at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
        at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
        at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
        at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
        at
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
        at
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:347)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
        at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:252)
        at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173)
        at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
        at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:202)
        at
        at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
        at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
        at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
        at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
        at
org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
        at
        at
org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
        at
        at
org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178)
        at
        at
org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
        at
        at
org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
        at
org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
        at
        at
        at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
        at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178)
        at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126)
        at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105)
        at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:107)
        at
org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:526)
        at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148)
        at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:856)
        at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.processConnection(Http11Protocol.java:744)
        at
org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:527)
        at
org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:80)
        at
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:684)
        at java.lang.Thread.run(Thread.java:568)
Best regards,
Bart
Bart van den Eijnden
OSGIS, Open Source GIS
http://www.osgis.nl
Hi list,
I have been having a similar issue with the SDE layers. Does anyone know why
this happens? Please help.
These are the things that I have tried:
1. War (version 1.6.2), Arcsde plugin (version 1.6.2), Arcsde extension
(9.2)
I use GAIA to add the sde layer, the layer comes out fine. However when I
tried to enforce the bounding box to filter (in GAIA) the feature I get the
following error message:
Result:
08 Apr 11:27:40 ERROR [data.ArcSDEQuery] - ***********************
filter: [ GID bbox POLYGON ((121.353394980568 -20.2262152662369,
121.353394980568 -17.6032546281861, 123.668107796084 -17.6032546281861,
123.668107796084 -20.2262152662369, 121.353394980568 -20.2262152662369)) ]
SQL: null
Source)
        at
        at
        at
        at
        at
        at
org.geoserver.feature.DecoratingFeatureCollection.getBounds(DecoratingFeatureCollection.java:141)
        at
        at
        at
        at
org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:357)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
        at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
        at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
        at
        at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
        at
        at
org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:69)
        at
        at
        at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
        at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
        at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
        at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
        at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
        at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:263)
        at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:844)
        at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:584)
        at
org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
        at java.lang.Thread.run(Thread.java:619)
When I use this version to getfeatue via Internet explorer it works fine.
http://tem00:8080/geoserver16Chris/wfs?service=wfs&version=1.0.0&request=getfeature&typename=sde:TEMP-001&maxfeatures=10&bbox=121.541768649894,-19.6668025512664,122.859064408888,-18.1740839291765
2. War (version nightly 04 08 2008), Arcsde plugin (version nightly 04 08
2008), Arcsde extension (9.2)
When I tried to select the layer in GAIA it gave me the following error
Result:
08 Apr 11:29:00 ERROR [geotools.data] - Error fetching row for
SDE.W_NATIVE_DET_REF[
Filter: Filter.INCLUDE
where clause sent: null
geometry filter:Filter.INCLUDE[SDE error -51][Error desc=DATABASE LEVEL
ERROR OCCURRED.][Extended desc=
org.geotools.arcsde.ArcSdeException: Error fetching row for
        at org.geotools.arcsde.data.ArcSDEQuery.fetch(ArcSDEQuery.java:792)
        at
org.geotools.arcsde.data.ArcSDEAttributeReader.hasNext(ArcSDEAttributeReader.java:216)
        at
org.geotools.data.DefaultFeatureReader.hasNext(DefaultFeatureReader.java:106)
        at
org.geotools.data.MaxFeatureReader.hasNext(MaxFeatureReader.java:78)
        at
org.geotools.feature.FeatureReaderIterator.hasNext(FeatureReaderIterator.java:50)
        at
org.geoserver.feature.RetypingFeatureCollection$RetypingIterator.hasNext(RetypingFeatureCollection.java:109)
        at
org.geotools.feature.collection.DelegateFeatureIterator.hasNext(DelegateFeatureIterator.java:50)
        at
org.geotools.data.crs.ForceCoordinateSystemIterator.hasNext(ForceCoordinateSystemIterator.java:140)
        at
        at
org.geotools.gml.producer.FeatureTransformer$FeatureTranslator.handleFeatureIterator(FeatureTransformer.java:508)
        at
org.geotools.gml.producer.FeatureTransformer$FeatureTranslator.encode(FeatureTransformer.java:460)
        at
        at
        at
        at
        at
        at
        at
        at
        at org.geoserver.ows.Dispatcher.response(Dispatcher.java:629)
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
Caused by: com.esri.sde.sdk.client.SeException:
        at com.esri.sde.sdk.client.k.v(Unknown Source)
        at com.esri.sde.sdk.client.k.d(Unknown Source)
        at com.esri.sde.sdk.client.SeQuery.fetch(Unknown Source)
        at org.geotools.arcsde.data.ArcSDEQuery.fetch(ArcSDEQuery.java:782)
        ... 65 more
08 Apr 11:29:00 INFO [geoserver.filters] - 151.130.157.10 "POST
/geoserver0804ASDE92/wfs" took 864ms
View this message in context: http://www.nabble.com/unpredictable-ArcSDE-behaviour-tp15587428p16547529.html
Dv_LGATE ha scritto:
Hi list,
Gabriel may provide better answers, but in the meantime, have you tried
out GeoServer 1.6.3 and the associated ArcSDE extensions?
It should have quite a bit of significant ArcSDE improvements.
(oh, rememeber you have to grab the extension distributed with 1.6.3,
the older ones won't work, extensions datastores do work only with
the geoserver version they are built for).
