[Geoserver-users] unpredictable ArcSDE behaviour
HI Andrea,
There is not much information that I can get from the geoserver.log file. The one message that I get is this:
2008-04-10 17:43:30,869 INFO [geoserver.filters] - 151.130.157.10 “POST /geoserver163/config/data/typeNewSubmit.do” “Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1; .NET CLR 1.1.4322)” “http://degs09:8080/geoserver163/config/data/typeNew.do
2008-04-10 17:43:31,123 WARN [action.RequestProcessor] - Unhandled Exception thrown: class java.lang.IllegalArgumentException
Cheers Dv
Deavi Purnomo
SLIP GIS Team
Information Management Division
Address: 1 Midland Square
Midland WA 6056
Phone: 08 9273 0786
Email: Deavi.Purnomo@anonymised.com
Website: http://www.landgate.wa.gov.au
-----Original Message-----
Sent: Thursday, 10 April 2008 3:09 PM
To: Deavi Purnomo
Cc: geoserver-users@lists.sourceforge.net; Gabriel Roldán; Chris Tweedie
Subject: Re: [Geoserver-users] unpredictable ArcSDE behaviour
Deavi Purnomo ha scritto:
Hi Andrea,
Thank you for your reply.
I have just tried the geoserver1.6.3. and it was working (Please note
that the feature is created based on the ArcSDE table). Although I must
say it took a long time to extract 1000 features (118329ms).
Ouch!
By using the new geoserver1.6.3 and the new arcSDE extension plugin, I
found another issue with the ArcSDE layers. When I want to create a new
ArcSde layer based on a view it did not allow me to create one and gave
me the following error message:
GeoServer - Exception
*The following exception was thrown: *
*java.lang.IllegalArgumentException: ArcSDE registered views can’t be
writable*
Do you have the full stack trace? (from the GeoServer logs).
This may help Gabriel work this out. But don’t expect a swift
solution… he’s out for a conference.
This e-mail and any files transmitted with it are intended only for the use of the addressee(s). It may contain information that is confidential and privileged, in which case neither is intended to be waived or lost by mistaken delivery to you. If you are not an intended recipient, any use, interference with, disclosure, distribution or copying of this material is unauthorised and prohibited. If you receive this e-mail in error, please notify the sender by return e-mail and delete the message and any attachments from your system. Unless specifically indicated, this e-mail does not constitute formal advice or commitment by the sender or the Western Australian Land Information Authority (Landgate). Information in this message not relating to the official business of Landgate shall be understood as neither given nor endorsed by it. It is your responsibility to check any attachments for viruses and defects before opening or sending them on. Landgate’s liability is limited to re-supplying affected attachments.
