The app-schema Feature Chaining documentation at http://docs.geoserver.org/stable/en/user/data/app-schema/feature-chaining.html says:
The current state of the User guide refers to setting up Geotools application schema configurations, and will be updated to reflect a Geoserver 2.0 configuration example shortly. For non-application schema configurations, please refer to Data Access Integration.
Versions supported
Feature chaining is implemented within the app-schemas module in GeoTools trunk (from 2.6.x on). Work on supporting this in Geoserver trunk is currently underway. It is not supported in GeoServer 1.6 community-schemas.
As far as I can see the rest of the documentation seems fine for current versions of GeoServer so can these sentences just be removed?
Marcus Sen
British Geological Survey
Keyworth
Nottingham
NG12 5GG
Web: http://www.bgs.ac.uk
This message (and any attachments) is for the recipient only. NERC is subject to the Freedom of Information Act 2000 and the contents of this email and any reply you make may be disclosed by NERC unless it is exempt from release under the Act. Any material supplied to NERC may be stored in an electronic records management system.
Yes, Marcus, these sections should be removed.
Kind regards,
Ben.
Versions supported
Marcus Sen
Keyworth
Nottingham
NG12 5GG
November Webinars for C, C++, Fortran Developers
Accelerate application performance with scalable programming models. Explore
techniques for threading, error checking, porting, and tuning. Get the most
from the latest Intel processors and coprocessors. See abstracts and register
http://pubads.g.doubleclick.net/gampad/clk?id=60136231&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
