Hi, desire to update my version of geoserver 1.5.3 to present, What process I must follow to obtain it??
I have Linux.
thanks
I have Linux.
thanks
it should be sufficient to start the new version (1.6.0 RC3). This usually means uploading a new .war file to Tomcat, and making sure that GEOSERVER_DATA_DIR (either an environment variable or defined in geoserver/WEB-INF/web.xml) points to your configuration.
Don't forget to make backups of everything first.
-Arne
I have Linux.
thanks
Defy all challenges. Microsoft(R) Visual Studio 2008.
Geoserver-users mailing list
https://lists.sourceforge.net/lists/listinfo/geoserver-users!DSPAM:4038,47ab4a46287291096210785!
but, will I not lose my files or proyects of the other version??
Arne Kepp escribió:
-Arne
I have Linux.
thanks
I am not sure what files / projects you are referring to, but all data associated with Geoserver should live in the directory defined by GEOSERVER_DATA_DIR, which you can read about here: http://docs.codehaus.org/display/GEOSDOC/4+GeoServer+Data+Directory
If you have never heard of it, then you probably need to copy the "conf" directory from your current GeoServer installation. As I mentioned, make a backup copy of it while you are there, but the new version of GeoServer should be able to use it without any problems.
-Arne
Arne Kepp escribió:
-Arne
I have Linux.
thanks
https://lists.sourceforge.net/lists/listinfo/geoserver-users!DSPAM:4038,47ab5ee93831804284693!
ok, I am understand,
thanks
P.D. in the folder data_dir I have my documents, pages and files js.
Arne Kepp escribió:
That should work,
however, in the long run I would recommend you start using the GEOSERVER_DATA_DIR, that way it's easier to make backups without including all the code and you'll have one less thing to worry about when upgrading.
-Arne
1. I will backup my all file of geoserver and will remove it.
2. I will install the new version.
3. I will replace the new folder data_dir with the old folder data_dir
4. I will pruve it.is right?
thanks
-Arne
Arne Kepp escribió:
-Arne
I have Linux.
thanks
https://lists.sourceforge.net/lists/listinfo/geoserver-users!DSPAM:4038,47ab63ef17355219720167!
Thanks Arne Kepp, all is working fine
Arne Kepp escribió:
That should work,
-Arne
thanks
-Arne
Arne Kepp escribió:
-Arne
I have Linux.
thanks
