[Geoserver-users] Updating Geoserver with the same old data directory?
I noticed that the xml structure catalog.xml has changed and I also suspect that there
might be other changes to the EPSG files and others in the data directory.
Is it really safe to migrate to a new version of geoserver while using the same data directory?
Will the new version check and update the files within it?
Thanks!
  • Pete
Hi Pete,
Pete DeVries wrote:
What version are you migrating from and to? Moving from GeoServer 1.4 to 1.5 raster support was added and additions were made to catalog.xml. However the format remains backwards compatable.
However, that being said there is this issue report that remains open:
http://jira.codehaus.org/browse/GEOS-1050
Which states that an sld file may need to be added to your data directory. However even if it is absent it should not result in a fatal error.
It should be. A later version of GeoServer should be able to read in an earlier version of the xml configuration files.
When you then resave the configuration the files will be written in the new format.
Thanks!
- Pete
!DSPAM:4007,46aea90f69726491211187!
Geoserver-users mailing list
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
