[Geoserver-users] Updating netCDF Data Store
I’m attempting to use the REST API to update an existing netCDF data store without any success.
For a bit of background: my group has built a system to harvest data from various sources on an hourly basis and put it all in a netCDF file. We hope to be able to update the existing data store rather than creating a new one with every update.
This is my current curl command:
curl -v -u username:password -XPUT -H “Content-Type: text/plain” -d “file///2015_archive_replacement_testing.nchttp://198.82.152.38:8080/geoserver/rest/workspaces/netCDFtesting/coveragestores/replacement_testing/file.netcdf
The error I get back is “Error while storing uploaded file::Unable to delete file: /path/to/file/replacement_testing.netcdf* Closing connection 1” I’ve checked, and the chmod of that file is 777.
Here are some questions I’ve been developing:
  1. Is the curl command correct?
  2. Does Geoserver 2.7.2 (with netCDF and netCDF output extensions) support updating netCDF files? If no, is there information about what needs to be implemented to build this functionality?
  3. Is the curl command using the correct interface (should it be datastores instead of coveragestores)? If it should be using datastores, then the answer to 2) is likely “no”, since that error message states: “Unsupported format: netcdf* Closing connection 1”
Brian
Brian Farrell
Project Associate
Center for Geospatial Information Technology
Dear Brian,
You could consider using an ImageMosaic coverageStore of NetCDF file(s).
At the moment it’s the only format implementing the harvest method (which is invoked when you send a REST update request similarly to what you did).
Harvest allows to add new granules to the collection or update existing ones.
Moreover, when the underlying NetCDF Reader (involved by ImageMosaic) notices that a file has been updated, it also does a reset of its internal index.
If my memory serves me right, some users already used this approach for time-growing NetCDFs.
That being said (in order to answer your questions):
  1. you can take a look here: http://docs.geoserver.org/latest/en/user/rest/examples/curl.html#uploading-and-modifying-a-image-mosaic
the XPOST commands
  1. yes, using imageMosaic. From a “pure NetCDF coverageStore” point of view, the harvest method isn’t implemented yet so the NetCDF reader should be reinit (GeoServer cache cleanup is probably needed).
  2. coverageStore is the right one.
Hope this helps.
Daniele
On Wed, Sep 16, 2015 at 12:16 AM, Brian Farrell <brian.farrell@anonymised.com3…> wrote:
Brian
Brian Farrell
Project Associate
Geoserver-users mailing list
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
