[Geoserver-users] Updating raster statistics using REST API
I am trying to update the raster statistics of a geotiff coverage using the REST API (as the statistics are not automatically filled by Geoserver AFAIK).
I get the .json description of the coverage [1], update the statistics values on it and send back the updated json [2] to Geoserver using a PUT request (to URL http://localhost:8080/geoserver/rest/workspaces/cesar/coveragestores/tmp_media_stats24/coverages/tmp_media_stats24.json).
However, I only get a HTTP 500 error code:
---- Debugging information ----
cause-exception : java.lang.RuntimeException
cause-message : null
class : org.geotools.coverage.grid.GridGeometry2D
required-type : org.geotools.coverage.grid.GridGeometry2D
converter-type : org.geoserver.config.util.XStreamPersister$GridGeometry2DConverter
line number : -1
class[1] : org.geoserver.catalog.impl.CoverageInfoImpl
converter-type[1] : org.geoserver.config.util.XStreamPersister$CoverageInfoConverter
version : 2.8.1
César Martínez Izquierdo
GIS developer
Blog: http://geotechnotes.wordpress.com/
ETC-SIA: http://sia.eionet.europa.eu/
Universitat Autònoma de Barcelona (SPAIN)
On Thu, Jan 28, 2016 at 9:58 AM, César Martínez Izquierdo <
cesar.izq@anonymised.com> wrote:
I've seen a similar problem on mailing lists [3] and tried the @class
workaround with no success (the error message looks different anyway).
@class? Not sure what you mean.
Do you have the full stack trace for your error?
Judging by the error, it _could_ be related to the XXE vulnerability fix,
and might require someone
to add the GridGeometry2D class to the de-serialization whilelist here:
https://github.com/geoserver/geoserver/blob/master/src/main/src/main/java/org/geoserver/config/util/XStreamPersister.java#L467
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
The @class workaround was suggested by Mike Grogan on a similar error [1], consiting on specifying the class of the dimension element: .
I am using JSON, so I translated this workaround as
{“dimensions”: {“coverageDimension” { “@class”: “org.geoserver.catalog.CoverageDimensionInfo”, … }}}
maybe it’s just non-sense.
The full strack trace is:
02 feb 09:54:38 ERROR [geoserver.rest] -
com.thoughtworks.xstream.converters.ConversionException: null : null
line number : -1
version : 2.8.1
On 28 January 2016 at 10:51, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Thu, Jan 28, 2016 at 9:58 AM, César Martínez Izquierdo <cesar.izq@anonymised.com> wrote:
I’ve seen a similar problem on mailing lists [3] and tried the @class workaround with no success (the error message looks different anyway).
Judging by the error, it could be related to the XXE vulnerability fix, and might require someone
Ing. Andrea Aime
@geowolf
Technical Lead
GIS developer
