Hello,
I made an upgrade from 2.2 to a version 2.3.2 this migration kept
the users but changed in one way or an other the passwords.
Is there a way to recover the passwords ?
Best regards,
Eric Smets
Eric Smets
Hello,
Best regards,
Eric Smets
Eric Smets
Eric,
if I’m not mistaken during the installation procedure geoserver creates a new file “masterpw.info” in the webapps\geserver\data\security directory (take a look at the creation date). Probably you can log in in the GUI with that.
regards,
Michele
On Mon, Jul 8, 2013 at 12:40 PM, Eric Smets <eric.smets@anonymised.com> wrote:
Hi Michele,
It seems, but I delete some time ago the masterpw.info and wrote this file down.
But the passwoords seems to be changed, as a result I can not login in the GUI.Al the other files seems OK to me, the data directory was form the 2.2.0 series.
There is only one version of geoserver running (2.3.2)regards,
Eric
Op 8/07/2013 12:28, Michele Beneventi schreef:
Hi Eric,
as you can read herehttp://docs.geoserver.org/latest/en/user/datadirectory/migrating.html
there should not be any issues except for some configuration file.
Have you got a shared geoserver data directory?Cheers
Michele-- Eric Smets [eric.smets@anonymised.com](mailto:eric.smets@...5451...) FKS bvba - Formal and Knowledge Systems [http://www.fks.be/](http://www.fks.be/) Schampbergstraat 32 Tel: ++32-(0)11-21 49 11 B-3511 Hasselt Fax: ++32-(0)11-22 04 19
On Mon, Jul 8, 2013 at 12:09 PM, Eric Smets <eric.smets@anonymised.com> wrote:
Hello,
the users but changed in one way or an other the passwords.Is there a way to recover the passwords ?
Best regards,
Eric Smets
Eric Smets
This SF.net email is sponsored by Windows:
Build for Windows Store.
http://p.sf.net/sfu/windows-dev2dev
Geoserver-users mailing list
If you want to have plain passwords you have to change the password encoder for the default user group service and recode the passwords. (Can be done from the GUI).
Christian
2013/7/8 Michele Beneventi <mbeneventi@anonymised.com>
Eric,
if I’m not mistaken during the installation procedure geoserver creates a new file “masterpw.info” in the webapps\geserver\data\security directory (take a look at the creation date). Probably you can log in in the GUI with that.regards,
Michele
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
Hi Michele,
Eric
Hi Eric,
Hello,
Best regards,
Eric Smets
Eric Smets
