I have just attempted to upgrade to GeoServer 2.4 from 2.3.5 but was unable to do so as the Tomcat was unable to start the application. I have successfully reverted to 2.3.5.
The procedure was to stop and undeploy GeoServer using the Tomcat manager, copy the new WAR into webapps, copy the MySQL JARs into the new libs, modify the new web.xml to point at my existing external data directory and add a resource-ref for JNDI, and fully restart the Tomcat.
Upon restarting, all I got when it came to starting up GeoServer was
26/09/2013 9:59:06 PM org.apache.catalina.core.StandardContext startInternal
SEVERE: Error listenerStart
so I got a suitable logging.properties in place and managed to expand this to the trace below. "jdbc_data" is a JNDI MySQL data source which is configured in the Tomcat's context.xml.
Does anyone know what the issue may be? Presumably something relating to my configuration.
Andrew
26/09/2013 9:59:06 PM org.apache.catalina.core.StandardContext listenerStart
SEVERE: Exception sending context initialized event to listener instance of class org.geoserver.platform.GeoServerContextLoaderListener
java.lang.RuntimeException: org.springframework.security.authentication.InsufficientAuthenticationException: Cannot access jdbc_data as anonymous
at org.geoserver.security.GeoServerSecurityManager.onApplicationEvent(GeoServerSecurityManager.java:327)
at org.springframework.context.event.SimpleApplicationEventMulticaster.multicastEvent(SimpleApplicationEventMulticaster.java:97)
at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:324)
at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:25)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4939)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5434)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:901)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:877)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:633)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:976)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1653)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
at java.util.concurrent.FutureTask.run(FutureTask.java:138)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
Caused by: org.springframework.security.authentication.InsufficientAuthenticationException: Cannot access jdbc_data as anonymous
at org.geoserver.security.SecureCatalogImpl.unauthorizedAccess(SecureCatalogImpl.java:878)
at org.geoserver.security.SecureCatalogImpl.buildWrapperPolicy(SecureCatalogImpl.java:856)
at org.geoserver.security.SecureCatalogImpl.checkAccess(SecureCatalogImpl.java:549)
at org.geoserver.security.SecureCatalogImpl.filterStores(SecureCatalogImpl.java:927)
at org.geoserver.security.SecureCatalogImpl.getStores(SecureCatalogImpl.java:430)
at org.geoserver.catalog.impl.AbstractFilteredCatalog.getStores(AbstractFilteredCatalog.java:352)
at org.geoserver.catalog.impl.AbstractCatalogDecorator.getStores(AbstractCatalogDecorator.java:117)
at org.geoserver.security.GeoServerSecurityManager.updateConfigurationFilesWithEncryptedFields(GeoServerSecurityManager.java:2842)
at org.geoserver.security.GeoServerSecurityManager.saveSecurityConfig(GeoServerSecurityManager.java:1390)
at org.geoserver.security.GeoServerSecurityManager.migrateFrom23(GeoServerSecurityManager.java:2385)
at org.geoserver.security.GeoServerSecurityManager.onApplicationEvent(GeoServerSecurityManager.java:325)
... 17 more
Hi Andrew
I seems that this error is caused by migration code. This code is triggered on startup and tries to modify the geoserver security dir. (contained in the geoserver data dir). I have no idea why this code should try to connect to a MYSQL database. Is there something special with your geoserver data dir ?
On Thu, Sep 26, 2013 at 2:37 PM, Andrew Miskelly <amiskelly@anonymised.com> wrote:
this to the trace below. “jdbc_data” is a JNDI MySQL data source which
is configured in the Tomcat’s context.xml.
my configuration.
Andrew
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by:
at
at
at
at
at
at
at
at
at
at
at
… 17 more
October Webinars: Code for Performance
Free Intel webinars can help you accelerate application performance.
Explore tips for MPI, OpenMP, advanced profiling, and more. Get the most from
the latest Intel processors and coprocessors. See abstracts and register >
http://pubads.g.doubleclick.net/gampad/clk?id=60133471&iu=/4140/ostg.clktrk
Geoserver-users mailing list
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
Hi Christian,
My geoserver data dir is a bog standard directory in /var/www.
The “jdbc_data” referred to is the name of a (MySQL JNDI) store in two of my workspaces. I assume the problem has something to do with either one of these and that it’s not necessarily trying to connect to the database.
Does that give you any hints?
Andrew
On 26/09/2013 23:05, Christian Mueller wrote:
Hi Andrew
my configuration.
Andrew
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by:
at
at
at
at
at
at
at
at
at
at
at
… 17 more
It may be related that now (having reverted to 2.3.5), when I attempt to run a WFS request against one of the layers using that data store I get the exception below. WMS requests come back fine.
java.lang.NullPointerException
org.geoserver.ows.CiteComplianceHack.preHandle(CiteComplianceHack.java:40)
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:914)
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
javax.servlet.http.HttpServlet.service(HttpServlet.java:621)
javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27)
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
org.geoserver.security.filter.GeoServerPreAuthenticationFilter.doFilter(GeoServerPreAuthenticationFilter.java:74)
org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
On 27/09/2013 08:51, Andrew Miskelly wrote:
Hi Christian,
Andrew
Hi Andrew
my configuration.
Andrew
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by:
at
at
at
at
at
at
at
at
at
at
at
… 17 more
[http://pubads.g.doubleclick.net/gampad/clk?id=60133471&iu=/4140/ostg.clktrk](http://pubads.g.doubleclick.net/gampad/clk?id=60133471&iu=/4140/ostg.clktrk)
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
