[Geoserver-users] Upgrade to GeoServer 2.4.2 from version 2.1.4 - one of our existing raster layers does not work with errors
Hi Shang,
Slightly unrelated, but I’d advise updating your Java to Java 6 Update 45 (the last in the Java 6 line) if only for security reasons (I think most issues are browser-plugin based, but this is Java).
Relating to your issue; have you tried removing the layer and store and then re-adding them?
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
On 5 December 2013 21:40, Shang Jin <Shang.Jin@anonymised.com> wrote:
Hello All,
We just upgraded our GeoServer from version 2.1.4 to version 2.4.2 including Oracle plugin. The GeoServer data directory is re-used when upgrading.
We have not installed GeoTools v10.2. The upgrading seems OK but we do have a problem with one raster layer.
The raster layer is called “RASTER_10K” with its style configuration like
2501
20000
When opening Layer Preview > OpenLayers for the “RASTER_10K” layer in the GeoServer 2.4.2, it displays a map at 1:2861 only. It displays a red X box behind the menu button without map at 1:11K and 1:5722 like the attached png file.
The “RASTER_10K” layer is a member of layer groups with other layers like “RASTER_50K” and “RASTER_250K”; those “RASTER_50K” and “RASTER_250K” layers do not have problem.
We could display maps at 1:11K, 1:5722 and 1:2861 scales on the GeoServer v2.1.4.
When I reproduced the preview the layer, the GeoServer v2.4.2 log file contains some errors like
2013-12-05 20:51:49,109 INFO [geoserver.wms] -
Request: getServiceInfo
2013-12-05 20:51:49,124 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Error rendering coverage on the fast path
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:331)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:251)
2013-12-05 20:51:54,734 ERROR [geotools.map] - Call MapContent dispose() to prevent memory leaks
2013-12-05 20:51:58,906 INFO [geoserver.wms] -
2013-12-05 20:51:58,921 ERROR [geoserver.ows] -
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:123)
Could you please help?
How to fix this problem? Do I need install GeoTools v10.2? Do I need install anything else?
The GeoServer runs on Windows Server 2008 R2 with Jetty web server; Java version 1.6.)_32 is used. We have also installed JAI 1.1.3 with GoeServer v2.1.4.
Thanks in advance.
Shang
PS: when we tested earlier, there are other errors with GeoServer 2.4.2 like:
2013-12-05 12:50:43,904 INFO [geoserver.wms] -
2013-12-05 12:50:43,904 WARN [geotools.rendering] - Unable to create this mosaic
org.geotools.data.DataSourceException: Unable to create this mosaic
at org.geotools.gce.imagemosaic.RasterLayerResponse.prepareResponse(RasterLayerResponse.java:1282)
at org.geotools.gce.imagemosaic.RasterLayerResponse.processRequest(RasterLayerResponse.java:1125)
at org.geotools.gce.imagemosaic.RasterLayerResponse.createResponse(RasterLayerResponse.java:1091)
CSD is working towards helping Suffolk become the greenest County.
Emails sent to and from this organisation will be monitored in accordance
with the law to ensure compliance with policies and to minimise any
security risks.
The information contained in this email or any of its attachments may be
privileged or confidential and is intended for the exclusive use of the
addressee. Any unauthorised use may be unlawful. If you receive this email
by mistake, please advise the sender immediately by using the reply
facility in your email software.
Customer Service Direct - a partnership between BT, Suffolk County Council
and Mid Suffolk District Council. Customer Service Direct Ltd.
Registered in England No. 05111581 Registered Office:81 Newgate
Street, London, EC1A 7AJ
Sponsored by Intel(R) XDK
Develop, test and display web and hybrid apps with a single code base.
Download it for free now!
http://pubads.g.doubleclick.net/gampad/clk?id=111408631&iu=/4140/ostg.clktrk
Geoserver-users mailing list
