The error "Could not determine format. Try setting the Content-type header." was raised
when I upload a raster data to geoserver by using the command :
curl -u admin:geoserver -v -XPUT -H 'Content-type: application/zip' \
--data-binary @classfield.zip \
http://localhost:8080/geoserver/rest/workspaces/geonode/coveragestores/ZZPDOWELL/classfield.geotiff
but it is obvious that i have gave the -H parameter to set the header, any suggestions will be help ?
Thanks
