On Thu, Feb 12, 2015 at 12:38 AM, Don <don_87@anonymised.com> wrote:
Dear GeoServer Users,
My apologies in advance in case this is an annoying question!
I am very new to GeoServer and can — also after reading the
documentation/manual, googling and browsing through older list posts — not
figure out how to solve my current problem:
I would like to upload .csv files to a GeoServer. Since we want to do this
automatically later on, I would like to use cURL to upload the files.
With this documentation
http://docs.geoserver.org/2.0.0/user/extensions/rest/rest-config-examples-curl.html I
am aware how to do the same thing with a .shp file.
I am, however, unable to translate this information into the .csv case,
i.e. I can’t figure out what changes/adaptions to the given example are
necessary so I can get .csv files onto the server instead of .shp files.
In order to do that, you first need a csv store, which GeoServer will have
in version 2.8.x I believe (to be released September),
and/or maybe as a community module earlier in the 2.7.x series.
However, the importer module can handle csv files, and I believe convert
them into a shapefile or something
else that GeoServer can use. It also has a rest api, but those that
contributed it, failed to document the
REST API, the tests in the module are not much help either I'm afraid.
I'm going to ask for some docs, see if they do have any, in any format
Sorry I could not be of much help
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
