[Geoserver-users] upload image mosaic
Dear Geoserver,
I’m trying to upload a tif file as a Mosaic image.
When I try to upload the file the following error get listed:
“Could not list layers for this store, an error occurred retrieving them: Argument “value” should not be null”.
Further the command Browse doesn’t appear so I have to type the directory.
any suggestion?
regards,
Marco
Hi Marco,
A couple of question so we can better understand the issue:
  • which version of geoserver are you using?
  • can you run a gdalinfo on your tif file?
Please, let us know.
Best Regards,
Daniele
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
On Mon, Mar 10, 2014 at 11:12 AM, marco casella <mcasella03@anonymised.com> wrote:
Dear Geoserver,
any suggestion?
regards,
Marco
Learn Graph Databases - Download FREE O’Reilly Book
“Graph Databases” is the definitive new guide to graph databases and their
applications. Written by three acclaimed leaders in the field,
this first edition is now available. Download your free book today!
http://p.sf.net/sfu/13534_NeoTech
Geoserver-users mailing list
Marco,
As far as I know the mosaic can be sent via the rest interface as zip file.
If you are using the GUI you have to select a folder which should be reachable by the geoserver (no file will be uploaded to the geoserver datadir).
I suggest to start passing the directory which contains the geotiff (it it is local to geoserver) and check the result.
If you are still getting the above error, please try adding some more info to the mail, such as:
  1. logs
  2. gdalinfo on the image
  3. other details on steps to reproduce
Carlo
any suggestion?
regards,
Marco
Dott. Carlo Cancellieri
@cancellieric
Software Engineer
I have often seen this if GeoServer does not have write permissions on the folder the file is on.
So if you created the folder under the GeoServer data dir as root (Under Linux) and the sever is running under Tomcat it may not be able to write to the directory.
Russ
  1. logs
Carlo
any suggestion?
regards,
Marco
@cancellieric
Software Engineer
