On Sun, Oct 5, 2014 at 9:46 AM, Harshad <har_desai@anonymised.com> wrote:
am using postgres database, my database has many schema.
my geometry table are distributed in these schema.
I want to upload these tables in geoserver. But it shows error for bounds
when i dont specify schema names, but table names are visible to publish,
but i cant get bounds to publish it.
I want to automate it for various table hence its not possible to specify
schema names manually.
Can you show us which commands you're trying to run?
But yes, generally speaking trying to publish from a database store without
specifying a schema does not always work well, especially if you have
different tables with the same name, but in different schemas
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
