[Geoserver-users] Upload SLD + SVG File
Hi everyone,
I use Geoserver version 2.5.2
I want to add my custom SLD With the svg in my geoserver. When i try to
validate my SLD i get this message :
Parsing failed for ExternalGraphic: java.lang.IllegalArgumentException: URI
is not absolute.
In the log file i get this message :
2014-08-13 09:07:29,901 WARN [geotools.styling] - can't parse
BOULANGERIE.svg as a java resource present in the classpath
Where can i put this file (svg) in my server ? How to configure the
classpath ?
Best regards,
Fabrice
View this message in context: http://osgeo-org.1560.x6.nabble.com/Upload-SLD-SVG-File-tp5156474.html
Hi Fabrice
I have SVG files in the Geoserver data_dir\workspaces\<workspacename>\styles\ folder.
These are referenced in the SLD like this:
--- Snip ---
               <ExternalGraphic>
                 <OnlineResource
                  xmlns:xlink="http://www.w3.org/1999/xlink&quot;
                  xlink:type="simple"
                  xlink:href="osmmsymbols/manmadeLandformPattern.svg"/>
                 <Format>image/svg+xml</Format>
               </ExternalGraphic>
--- Snip ---
Full example:
  <FeatureTypeStyle>
     <Rule>
     <Name>Slope (pattern) - 1:35 to 1:4,500</Name>
       <ogc:Filter>
     <ogc:Or>
           <ogc:PropertyIsEqualTo>
             <ogc:PropertyName>osmmstyle_name</ogc:PropertyName>
             <ogc:Literal>slopeFill</ogc:Literal>
           </ogc:PropertyIsEqualTo>
             <ogc:Literal>slopeHistoricFill</ogc:Literal>
     </ogc:Or>
       </ogc:Filter>
       <MinScaleDenominator>35</MinScaleDenominator>
       <MaxScaleDenominator>4500</MaxScaleDenominator>
       <PolygonSymbolizer uom="http://www.opengeospatial.org/se/units/metre&quot;&gt;
         <Fill>
           <GraphicFill>
             <Graphic>
               <ExternalGraphic>
                 <OnlineResource
                  xlink:type="simple"
               </ExternalGraphic>
               <Size>24</Size>
               <Rotation>0</Rotation>
             </Graphic>
           </GraphicFill>
         </Fill>
       </PolygonSymbolizer>
     </Rule>
  </FeatureTypeStyle>
Ross
-----Original Message-----
From: ibFabrice [mailto:irie.fabrice@anonymised.com]
Sent: 14 August 2014 21:31
Subject: [Geoserver-users] Upload SLD + SVG File
Hi everyone,
I want to add my custom SLD With the svg in my geoserver. When i try to validate my SLD i get this message :
Parsing failed for ExternalGraphic: java.lang.IllegalArgumentException: URI is not absolute.
2014-08-13 09:07:29,901 WARN [geotools.styling] - can't parse BOULANGERIE.svg as a java resource present in the classpath
Where can i put this file (svg) in my server ? How to configure the classpath ?
Best regards,
Fabrice
Geoserver-users mailing list
This message is strictly confidential. If you have received this in error, please inform the sender and remove it from your system. If received in error you may not copy, print, forward or use it or any attachment in any way. This message is not capable of creating a legal contract or a binding representation and does not represent the views of Angus Council. Emails may be monitored for security and network management reasons. Messages containing inappropriate content may be intercepted. Angus Council does not accept any liability for any harm that may be caused to the recipient system or data on it by this message or any attachment.
Hi Mr McDonalds,
Thanks for your reply.
In your sample i think it’s SLD 1.0.0 I’m using qgis to produce my sld (1.1.0)
it’s not working for me.
Second thing, i not see the folder data_dir\workspaces<workspacename>\styles\ in my install. It’s normal ?
Best regards,
Fabrice
2014-08-15 10:30 GMT+02:00 McDonaldR [via OSGeo.org] <[hidden email]>:
Hi Fabrice
I have SVG files in the Geoserver data_dir\workspaces<workspacename>\styles\ folder.
— Snip —
image/svg+xml
— Snip —
Full example:
Slope (pattern) - 1:35 to 1:4,500 osmmstyle_name slopeFill osmmstyle_name slopeHistoricFill 35 4500 image/svg+xml 24 0
Ross
To: [hidden email]
Hi everyone,
2014-08-13 09:07:29,901 WARN [geotools.styling] - can’t parse BOULANGERIE.svg as a java resource present in the classpath
Best regards,
Fabrice
[hidden email]
[hidden email]
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Upload-SLD-SVG-File-tp5156474p5156515.html
To unsubscribe from Upload SLD + SVG File, click here.
NAML
you never know how far you can go until you try…
